4 hours ago, VVarrior said:
can I also try the beta firmware??
Sent. It is a trial, not a beta so probably won't be very stable - you're unlikely to notice any difference unless you need the features mentioned above.
I won't be providing it to anyone else now unless you need the features I mentioned.
ok thanks all give it a try all give you some feedback on it see how it goes
  • 1 year later...
15 hours ago, cjenks22 said:
Did you fix this issue , i have the exact same problem using wierless 5ghz
So for 5GHz, it's not adhering to your Congestion Control settings? What router & firmware version are you using?
Hi,
Both wireless bands have the same issue,
XR1000 on the 1.64.49 firmware
I should mention , QOS works on always for download but not upload speed.
14 minutes ago, cjenks22 said:
Hi,
I think that may be a separate issue - are you using PPPoE, VLAN or DHCP Identifiers?
I reset the router same issue with wireless
QOS upload and download works with Ethernet only ( when i unplug ethenet and connect to my wireless adapter i get full speeds no qos applied.
I am using dhcp connected to my sky sr203 , ( it does not have bridge mode )
Thanks for that, I'm not seeing anything unusual but could you change the mode for 5GHz down to 2400 please and see if that makes any difference? Are you using Armor?
Hi Frazer i manged to fix this issue , previously i have been using the sky router sr204 which does not have bridge or modem mode , i managed to get a BT Open Reach Huawei EchoLife HG612 modem and this have fixed my issue.
Good job! Do let us know if you have any further issues or questions.
  • 2 weeks later...
Just an update on this , it has reverted back to it's old ways for some reason , this time download QOS works wirelessly but upload does not  , scratching my head rn.
Has anything settings or setup wise changed since then?
  • 2 months later...
The above issue is fixed , seems to have fixed it's self , but now i have another , devices randomly disconnect from wifi and are unable to connect again unless i restart the router  ,any ideas?
Could you provide the log from the System Information page when you see this happen please?
Yes i will report back when this happens Fraser , another thing i noticed , i can only connect to either 5gz or 2.4gz , if i want to change i need to restart the device.
Great thanks, it's also worth upgrading to the new version just in case that helps at all. What do you mean exactly, you connect but it doesn't get internet until you reboot the device?
Meaning that , the wifi connects but shows "no internet" . i then have to reboot the router forget wifi and reconnect again .
Understood, what are the devices specifically that are having this issue?
