Packet loss and lag spikes while playing (xr500)
AzeRuS94
45 minutes ago, AzeRuS94 said:
Hello, I've been having packet loss 1/2% on both upload and download in the in-game graph everyday. I don't think that the servers are like this always because my friends play fine. What can I do? I have anti-bufferbloat on always 50/50% and I can't play due to this frustration.
Does it have a noticeable impact on the connection in game? If you use PingPlotter do you see the same kind of packet loss occurring?
  • Replies 69
Ping is stable at 30ms but I have 3% packet loss every game non-stop lagging. What do I have to do with ping plotter?
Follow this guide but no need to change QoS at this point, just run it at a time where you would be normally playing and post the results here please.
Where can I find the guide?
Edit: I found it. This is a test with a few devices being used and me playing with 50/50% qos.
How does it looks? The taskbar has hidden some red triangles that I don't know what they mean, they are at the bottom of the graph.
That looks really good actually, no indications of packet loss there. Can you use 8.8.8.8 with PingPlotter also please and post that?
This is with 8.8.8.8
That's absolutely perfect, if you try Apex now for example does it still show packet loss? If so grab the IP from the Geo-Filter and do a PingPlotter test with that.
Hello, I solved the packet issue thanks to a optimization internet guide, but the problem is that I still experiencing since october a lot of wifi drops every 1-2 days where there is no internet connection but on the isp router everything is fine. The only fix I found was to restart the router but is very annoying. What can I do?
3 minutes ago, Netduma Fraser said:
That's great news! Give your devices reserved IPs in LAN Settings and that should help.
Every device? I have like 13-14 devices.
I'd recommend so, it should be quite easy as in LAN Settings you just click the device from the table to apply the IP it already has.
I did it with every device 👍, hope that this wifi drops stops. Thanks for your help.
The wifi just dropped 3 times today while playing csgo. No internet through wifi or ethernet. Since I tried in september duma os 3.0 and rolled back to 2.66 everything went worse and worse everyday, I can't even returned it because the router has over 1 year.
Try the recent beta build we released last week as I think that is better generally and haven't seen to many reports of that.
Where do I find the beta?
Edit: I found it, there is a lot of people complaining, I know it's a beta but I preefer to not damage more my xr500 and I will wait for an official release of dumaOS 3.0, until then I will be using my isp router.
It's a beta so there will be issues but I think it's more stable than the previous build.
