Administrators Netduma Fraser Posted October 31, 2020 Administrators Posted October 31, 2020 That's great, nothing else should be needed. Keep us posted!
AzeRuS94 Posted October 31, 2020 Author Posted October 31, 2020 5 hours ago, Netduma Fraser said: That's great, nothing else should be needed. Keep us posted! Just happened again, I'm going to downgrade to 2.56 again because when I was using it, this wasn't happening. Edit: I went back to 2.56 and now when I try to access to the duma interface it says: This R-App is not loaded yet, please try again in a minute. I rebooted the router twice but nothing.
Administrators Netduma Fraser Posted October 31, 2020 Administrators Posted October 31, 2020 Upgrade using TFTP and then do a factory reset, that will give you the freshest install possible and should resolve any outstanding issues https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
AzeRuS94 Posted November 4, 2020 Author Posted November 4, 2020 On 10/31/2020 at 8:44 PM, Netduma Fraser said: Upgrade using TFTP and then do a factory reset, that will give you the freshest install possible and should resolve any outstanding issues https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP I have done everything and now it's fine but my samsung galaxy s20 plus has a very slow internet, I can't even watch a video on youtube because it's buffering, my speeds are fine while doing a speedtest. What can I do?
Administrators Netduma Fraser Posted November 4, 2020 Administrators Posted November 4, 2020 Set the DNS on your phone to use 1.1.1.1 & 1.0.0.1 and see if that speeds it up
AzeRuS94 Posted November 4, 2020 Author Posted November 4, 2020 12 minutes ago, Netduma Fraser said: Set the DNS on your phone to use 1.1.1.1 & 1.0.0.1 and see if that speeds it up nvm, all the devices have a slow wifi. What can I do? The isp wifi works perfectly fine.
Administrators Netduma Fraser Posted November 4, 2020 Administrators Posted November 4, 2020 47 minutes ago, AzeRuS94 said: nvm, all the devices have a slow wifi. What can I do? The isp wifi works perfectly fine. Do the wired devices have slow internet as well?
AzeRuS94 Posted November 4, 2020 Author Posted November 4, 2020 9 minutes ago, Netduma Fraser said: Do the wired devices have slow internet as well? nop, only wifi.
Administrators Netduma Fraser Posted November 4, 2020 Administrators Posted November 4, 2020 Are you using Smart Connect? If so disable this and connect manually to 5GHz, does it work better then?
AzeRuS94 Posted November 6, 2020 Author Posted November 6, 2020 On 11/4/2020 at 11:03 PM, Netduma Fraser said: Are you using Smart Connect? If so disable this and connect manually to 5GHz, does it work better then? I don't use smart connect and I always use 5ghz
Administrators Netduma Fraser Posted November 6, 2020 Administrators Posted November 6, 2020 There is no real reason there should be a difference between the speed tests and websites, other than DNS & Adblocker which you don't have. Could be wireless contention, use a WiFi analyzer to find the least congested channels and then change to that.
AzeRuS94 Posted November 7, 2020 Author Posted November 7, 2020 On 11/6/2020 at 3:30 PM, Netduma Fraser said: There is no real reason there should be a difference between the speed tests and websites, other than DNS & Adblocker which you don't have. Could be wireless contention, use a WiFi analyzer to find the least congested channels and then change to that. These are the channels available. Is there a difference between all the 5ghz channels? Should I use a specific number or it doesn't matter? Because they are 5 stars each. Thanks for your help.
Administrators Netduma Fraser Posted November 7, 2020 Administrators Posted November 7, 2020 That does seem promising but hard to recommend one because as you say they're all basically 5 stars. Would be better if we could see what other networks are using. There is a WiFi analyzer on the Microsoft Store for Windows 10 that is free that will tell you this, do that and post the screenshot and I can recommend one.
AzeRuS94 Posted November 7, 2020 Author Posted November 7, 2020 3 hours ago, Netduma Fraser said: That does seem promising but hard to recommend one because as you say they're all basically 5 stars. Would be better if we could see what other networks are using. There is a WiFi analyzer on the Microsoft Store for Windows 10 that is free that will tell you this, do that and post the screenshot and I can recommend one. I installed it but it requires a wifi card and my pc doesn't have it, because is desktop pc.
Administrators Netduma Fraser Posted November 7, 2020 Administrators Posted November 7, 2020 Okay no problem, change 5GHz to 36 and leave 2.4 as it is.
AzeRuS94 Posted November 13, 2020 Author Posted November 13, 2020 On 11/7/2020 at 8:07 PM, Netduma Fraser said: Okay no problem, change 5GHz to 36 and leave 2.4 as it is. Hello, It's been nearly a week and I didn't experienced any wifi drop out or anything like before, I'm currently on 2.3.2.66 and whenever I play games like Fortnite, Csgo or MW, I'm experiencing lag and packet loss (especially on fortnite). I have qos 70/70. What can I do?
Administrators Netduma Fraser Posted November 13, 2020 Administrators Posted November 13, 2020 Where are you measuring the packet loss exactly? Do you get the packet loss directly connected to the modem?
AzeRuS94 Posted November 14, 2020 Author Posted November 14, 2020 23 hours ago, Netduma Fraser said: Where are you measuring the packet loss exactly? 23 hours ago, Netduma Fraser said: Do you get the packet loss directly connected to the modem? Nop, I tried it this morning and everything was smooth.
Administrators Netduma Fraser Posted November 14, 2020 Administrators Posted November 14, 2020 Where are you measuring the loss?
AzeRuS94 Posted November 15, 2020 Author Posted November 15, 2020 18 hours ago, Netduma Fraser said: Where are you measuring the loss? For example, While playing Fortnite, the net-graph in-game shows 1-3% packet loss with the yellow wifi alert.
Administrators Netduma Fraser Posted November 15, 2020 Administrators Posted November 15, 2020 Are you playing through WiFi or ethernet? It is most likely the server itself under load.
AzeRuS94 Posted November 15, 2020 Author Posted November 15, 2020 Just now, Netduma Fraser said: Are you playing through WiFi or ethernet? It is most likely the server itself under load. Always ethernet.
Administrators Netduma Fraser Posted November 15, 2020 Administrators Posted November 15, 2020 I think that will be just the server, Apex does the same to me recently and I've not changed anything in my setup.
AzeRuS94 Posted November 15, 2020 Author Posted November 15, 2020 1 hour ago, Netduma Fraser said: I think that will be just the server, Apex does the same to me recently and I've not changed anything in my setup. Okay, thanks for your help
AzeRuS94 Posted November 27, 2020 Author Posted November 27, 2020 On 11/15/2020 at 5:03 PM, Netduma Fraser said: I think that will be just the server, Apex does the same to me recently and I've not changed anything in my setup. Hello, I've been having packet loss 1/2% on both upload and download in the in-game graph everyday. I don't think that the servers are like this always because my friends play fine. What can I do? I have anti-bufferbloat on always 50/50% and I can't play due to this frustration.
