EezyGamer Posted January 29, 2020 Author Posted January 29, 2020 couldnt see any other ports that was the only one visable, may be something to do with the interface doesnt work properly on phone, but not sure. also I have disconnected everything before and used a single 1m cat 6 cable to connect the netduma and the ISP router and got the same speedtest results as now so it can't be the wire, has to be the way the systems are interacting
Bert Posted January 29, 2020 Posted January 29, 2020 When you used a 1m cat6 cable between your ISP router and R1, did you do the test over wifi? R1's wifi won't support 200mbit afaik. But what you can do is rig up that same setup, with the cat6 cable and look at that ports screen again in R1, and see if port 1 PoE now reports 1000M/full or if it's still stuck at 100M.
EezyGamer Posted January 29, 2020 Author Posted January 29, 2020 i did test over wifi, okay I will set it up again then and get back to you
EezyGamer Posted January 29, 2020 Author Posted January 29, 2020 right case closed, found the issue and I am embarrassed to say it was because one of the long ethernet from the ISP to the R1 was a cat 2 cable which I dint know because I didnt buy it, just replaced the cable and tried a speedtest on my PC I'm now hitting close to full speed. thanks for the help you guys!
Administrators Netduma Fraser Posted January 29, 2020 Administrators Posted January 29, 2020 Great to hear you managed to resolve the issue! No need to be embarassed, sometimes it's simple and sometimes it's not, having fresh eyes on it can make the world of difference! As it's resolved I'll close this topic, feel free to open another if you have any more issues/questions.
