kinel Posted November 24, 2019 Posted November 24, 2019 I had to go back to the older firmware for a big reason And i cant see myself going back to the new firmware The reason is because it has the network monitor that shows you the ports that cod mw uses And thers a lot So what i wanted to know will the new cloud update when you guys complete it be usable for the older dumar firmware 1.306j i think its called Also do you think the old firmware would be able to ban servers atm they can only temp ban
Administrators Netduma Alex Posted November 25, 2019 Administrators Posted November 25, 2019 Our cloud updates will work on DumaOS and the Original Firmware. The same cloud updates work between both. I've not got much experience with the old firmware myself so i'll need to check with the devs if there's a way to permanently ban on the old firmware. We won't be doing any updates to the old firmware, besides the cloud updates that is.
Administrators Netduma Fraser Posted November 27, 2019 Administrators Posted November 27, 2019 Old firmware cannot permanently ban servers and we won't be doing any software updates for the original firmware so temp ban is all you have available for that purpose.
Keith Posted November 30, 2019 Posted November 30, 2019 Does the original R1 and original firmware still show where all clients are connecting from in a COD match? I want to look into SBMM actually prioritizing connections. I am constantly getting good local servers via my XR500, but I question where all of the players are connecting from.
Administrators Netduma Fraser Posted November 30, 2019 Administrators Posted November 30, 2019 25 minutes ago, Keith said: Does the original R1 and original firmware still show where all clients are connecting from in a COD match? I want to look into SBMM actually prioritizing connections. I am constantly getting good local servers via my XR500, but I question where all of the players are connecting from. That will not always happen when connecting to server based games as you don't have a direct connection to the other players only the server. You may sometimes see it but I wouldn't expect it.
