Port 5000 not working on WIFI - XR500 Running V2.3.2.40
The firmware's going through final testing right now, so unless any major issues are found...
  • Replies 59
So roughly when?
Also is the issue that we are reporting going to be looked at?
Surely VLAN tagging should only be used on the WAN side not also the LAN?
I can't say when, it's up to NETGEAR to decide when they release it.
And yes we're going to look at this issue, although I have a feeling it's caused by netgear's part of the software.
Thanks. So if it is a Netgear issue are you going to take it up with them or do we need to? They fixed this poor bug in other routers. Hardly fitting for one of there flagship routers to have such a silly floor. It is not only an issue with NAS' but also IP cameras etc....
Cheers.
Well, it turns out I've managed to fix it, in a round about kind of way.
I'm using a DM200 Modem with the XR500. If you want the DM200 to handle the VLAN settings, instead of the XR500, you have to set them up when the modem is in Modem/Router mode and then change it to modem only and do not allow VLAN passthrough.
After hours of frustration, I'm just glad I've managed to figure this out.
Great to hear that, thanks for posting a solution!
I can confirm that the above solution also works for me. Crazy but it does work.
Basically do not let the XR500 handle any of the VLAN stuff for you and amazingly all works fine.
Thank you JoshGre, you saved me buying a switch. This stupid issue has already forced me to buy other NAS, so now I have two 😞
Great to hear that, hopefully we can get this resolved shortly in an update :)
Fraser,
From what I understand from the research I did, the problems arise because there is no option to on the router to use a VLAN ID on just the WAN traffic, what's happening is there is some issue when using VLAN with the options you have on the router where it will tag all traffic, which means even LAN traffic is VLAN tagged which is causing a routing issue.
The best way I can think to resolve it is to be able to tag the 'internet'  port as you call it on the device manager and then all will be fine.
Thanks
Josh
5 minutes ago, JoshGre said:
Fraser,
Thanks
Josh
I think you're right as when I tested it myself I found that to be the case so I think when that is done its just a case of double checking/fixing QoS with that and it should be fine.
  • 1 month later...
Facing a similar issue with 2.3.2.56 where I am unable to access port 5000 on my Synology Diskstation. I'm on CenturyLink with VLAN tagging enabled and this is an absolute pain as I'm also unable to back up my MacBook via Time Machine as it never connects. What are next steps...?
Looking at the topic it's something Netgear are aware of and need to fix. If you could get another router to handle VLAN so the XR500 doesn't then that would work but nothing else you could do at the moment.
Thanks for the update. I actually purchased the XR500 to remove a CenturyLink router in concert with a TP-LINK, so that I could have one router own it all.
The testing you referred to back in late July, is that still underway? Assuming that's not the version I am on...?
  • 1 month later...
  • 3 weeks later...
22 minutes ago, Aaron M. said:
Still routine issues with this router. Any word on an update...?
I will ask Alex but I assume he has been busy trying to make CoD as compatibile as possible with the cloud.
Unfortunately this really is a problem that only NETGEAR can sort out, as it pertains specifically to their section of the firmware. I will however contact them to confirm that they're aware of this issue.
Guest Killhippie
Don't hold your breath, Alex.
  • 2 weeks later...
@Netduma Alex Appreciate the response.
Interestingly enough, this issue also affects my Philips Hue bridge and the ability for the mobile app to connect and control the lights. I've read the handful of other posts on the topic and I'm 100% certain that the common underlying issue is anyone making use of the VLAN 201 tagging with Century Link.
Perhaps we can refocus efforts on that specific set up? I'm hesitant to open a case since I witnessed someone else go through that exercise in another thread to no avail and knowing that VLAN 201 tagging is the culprit, we need a developer to take a look!
That's very interesting thank you for the information, that is something that would require Netgear to look at as we don't cover that aspect of the router. I would suggest you make a case and then we can push them from our side as well. It's more to make them aware rather than expecting a quick fix as it will require a dev to fix it.
Case number is: 41993256
Calling in was an absolute nightmare so anything you can do to help -- thank you in advance!
Sorry to hear that but thank you for the number. I've asked our team to push NG on this case.
Any movement by chance?
