Pingplotter Help
Alix
Hi during the day I get all A grades  from dslreports.com from the netduma router upstairs but if I connected the main router I don't get all A grades. On a night I find my self changing settings on the netduma. So today I connected my phone and tablet to the downstairs router and run a YouTube video and downloaded a game at the same time and run pingplotter for a bit. The results are in the photo labeled downstairs main router. Did the same on the netduma router upstairs again the results are labeled netduma upstairs. Do you think I have it set up right thanks for any advice
Powerline adapter's also anti-bufferbloat must work using powerline adapter's as I get all A from the netduma from dslreports.com and don't get all A grades from downstairs router which as no qos set on it
Well the results seem largely similar. This may be because the NetDuma router cannot control traffic from devices which are upstream from it. For example, anything connected to the other router (not Netduma) cannot be controlled by the Netduma. This makes the QoS settings kind of pointless.
The ideal setup would be to swap the routers so that you have the Netduma where the connection comes into the house, and the other router used to extend the network. This might not be possible though depending on your ISP.
The advantage of a setup like that is that the Netduma would control everything on the network and improve the ping stability for everybody.
I did also put into the main router downstairs the netduma wan ip address into dmz seems to be okay no double natting
So qos no good for the xbox using the powerline adapters with the netduma?. Any reason why I get better grades with dslreports using the netduma and not ASUS router which as no qos?
Honestly I don't actually know how DSLreports judges your QoS. I might need to ask one of the developers.
The QoS will work but only for devices connected to the Netduma. For example, let's say you have your Xbox connected to the Netduma playing a game, and also your laptop connected to the Netduma, streaming a movie. The Netduma will limit the bandwidth that the laptop can use for the movie, meaning there is still room for your game.
Now let's say you had the exact same setup except that the laptop was connected to the other router instead of the Netduma. Now the laptop will be free to use as much bandwidth as it can to stream that movie, and your Netduma router won't be able to stop it. This means that your game on Xbox might start lagging because the movie is using up all of the bandwidth.
This video that we made a while ago actually explains it really well:
So I could basically connect the now tv box to the netduma and other devices to the netduma as well would that work okay with the powerline adapters
Yes absolutely. But if you did that, it would make me wonder why you don't just put the other router into bridge mode? Is it a combined router and modem?
😊 Because I don't know how to setup bridge mode and this was the easy way lol. Was my ping graphs from ping plotter that I sent okay
Do not use dsl reports. That site is trash. I used to use it. Ping is the only thing that matters so stick to ping plotter, absolutely. Toy around with your sliders until you get the least amount of spikes. Mine is set at 40d/70up. I spent about an hour on there to figure it out. If the game isn't playing well or right then you know its not on your its the shit servers. I'm going to make a video on the best way to use ping plotter down the road.
What confused me is that I get good reading from dsl reports in the morning about tea time dslreports changed so was changing settings just so confused. Don't know if it's because I have whisp Internet and anything can change
Hi If you get spikes in ping plotter what are you meant to do decrease the sliders or increase them
That's what I was confused about do I decrease or increase the sliders when there is a ping spikes thank you very much for making that clear for me and thanks for the link. Do you think having wireless Internet and not getting the same speeds all the time doesn't help in spikes 🤔
As in your internet comes through wirelessly from an access point? Yes that certainly wouldn't help, your base ping will likely fluctuate quite a bit but theres not much you can do about that.
Basically I can only make it good not perfect lol thanks netduma didn't know what I was doing at first but got a good idea now how it all works 😊
