sikpup Posted March 21, 2019 Share Posted March 21, 2019 So I have to say I am kind of frustrated. I "upgraded" to the new os and find it slow and less user friendly than the old OS... that aside, the GEO filter for Apex legends is not working for me. I followed the guide and it maybe will connect to one game, then I will get booted back to title screen after game and it will say attempting to login to EA servers. It then sits in a loop until it finally says that connection to EA servers could not be made. I then cannot get into another game unless I remove the PS4 from my device list and reboot the game. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 21, 2019 Administrators Share Posted March 21, 2019 What do you find slow about it? We actually designed it to be MORE user friendly, what don't you find user friendly about it? I'm not sure if that is completely related to the Geo-Filter as I have experienced this many times when testing through ISP hub. We released a cloud update this week for Apex, flush the cloud, does it improve your experience then? Link to comment Share on other sites More sharing options...
sikpup Posted March 23, 2019 Author Share Posted March 23, 2019 I flush the cloud and it works for maybe one game - then same problem. It will kick me back to the title screen and try to reconnect 9 times. After the 9th try i get the message "Unable to connect to EA servers Please check your internet connection and try again.". It then only works again if I flush and repeat. Works for maybe (maybe!) one game then the same problem. As for the new front end, I guess I am just old school. It takes a while for each app to load and I do miss the ability to put VPN settings directly into the router as well. It literally takes like 20 - 30 seconds for the apps to load. Maybe its a problem with the router itself as my geo-filter clearly isn't working either. migueltaveras6 1 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 23, 2019 Administrators Share Posted March 23, 2019 Okay so to clarify: No Geo-Filter/Spectating Mode = Can game no problem without being kicked back to the lobby? Geo-Filter in Filtering Mode = 1 game works, then kicked to lobby, flush cloud, allowed back to the lobby and then one game allowed and repeat Is that correct? R-App loading should be at a decent speed. Have you done a factory reset since updating to DumaOS? If so have you cleared your browser cache/cookies? They should speed it up. You can still put the same VPN Settings into the router that you did with the original firmware. If you're not sure how to do so let me know what you're wanting to achieve and I can help. Link to comment Share on other sites More sharing options...
sikpup Posted March 25, 2019 Author Share Posted March 25, 2019 Yes, that is correct. - And there are many times where I simply cant just flush cloud to get it to work. I have to remove my ps4 as a device and start all over. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 26, 2019 Administrators Share Posted March 26, 2019 When you're kicked to the lobby and can no longer connect back with filtering mode please look at the map, do you see anything blocked? If so please ping it and provide us with the ID Link to comment Share on other sites More sharing options...
sikpup Posted March 26, 2019 Author Share Posted March 26, 2019 The map is empty. In fact, even when I play and it does work it only ever shows one connection (to somewhere in michigan) - and I am in NY. There is literally never another server. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 27, 2019 Administrators Share Posted March 27, 2019 Could you provide a screenshot of the entire Geo-Filter please when you've been booted back to the lobby/trying to reconnect Link to comment Share on other sites More sharing options...
sikpup Posted March 27, 2019 Author Share Posted March 27, 2019 Ok the first screen is what I get when looking for a game at first. Note the only server that ever shows is in Michigan. If I don't set circle that far I can NEVER find a game to begin with. Then, after a game or two (just this morning I got two!!!) it kicks me back to title screen saying attempting reconnection and this is what is on my router screen. Nada. I then have to delete the ps4 and start all over again (which frankly I have not even bothered to do because its so time consuming). Just really frustrated because this game is terrible with bad connections. Link to comment Share on other sites More sharing options...
sikpup Posted March 27, 2019 Author Share Posted March 27, 2019 Update, I reset my router to factory settings and the problem persists. Now there is a new wrinkle: I can get into the game but literally every time it says starting server, it drops me back to title screen and says : Connection to Host lost. I give up. It simply does not work. Too much work to try and get a game that isnt laggy. Sigh. Link to comment Share on other sites More sharing options...
sikpup Posted March 27, 2019 Author Share Posted March 27, 2019 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 27, 2019 Administrators Share Posted March 27, 2019 Can you zoom out of the map please as theres most likely something blocked elsewhere and have a look. Rule of thumb: If the Geo-Filter isn't working zoom out of the map to make sure you're not missing anything Link to comment Share on other sites More sharing options...
migueltaveras6 Posted February 3, 2020 Share Posted February 3, 2020 I'm currently having this problem and it's been happening since I got the xr500 Link to comment Share on other sites More sharing options...
Netduma Alex Posted February 4, 2020 Share Posted February 4, 2020 Does it just happen with Apex? Sounds like we might need to test Apex again. Link to comment Share on other sites More sharing options...
EricSe7en Posted February 4, 2020 Share Posted February 4, 2020 I also get this issue. I have to close the game and restart to get back into the lobby. Link to comment Share on other sites More sharing options...
Netduma Alex Posted February 4, 2020 Share Posted February 4, 2020 2 hours ago, EricSe7en said: I also get this issue. I have to close the game and restart to get back into the lobby. So, after a match you get kicked to the start screen and have to restart the game? Link to comment Share on other sites More sharing options...
EricSe7en Posted February 4, 2020 Share Posted February 4, 2020 It's not every match, but it does happen regularly - it's the code 'leaf' message. If i'm using spectate mode, there are no issues, it's only when filter mode is on. Sometimes it will re connect to the lobby, other times it will try many times, but ultimately fail. Once this happens, the only way to reconnect is to close the game and restart it. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 4, 2020 Administrators Share Posted February 4, 2020 There will be something being blocked on the Geo-Filter when that occurs, look at the Geo-Filter Map quickly and allow the icon that appears blocked and that should resolve it. Please also then let us know the ID so we can whitelist it in the cloud. Link to comment Share on other sites More sharing options...
Sir Techie Posted February 5, 2020 Share Posted February 5, 2020 Same thing also happens to me I have checked the map and nothing is blocked. Link to comment Share on other sites More sharing options...
Netduma Alex Posted February 5, 2020 Share Posted February 5, 2020 Welcome to the forum! I think we'll need to do more testing, see if we can recreate this issue in the office. Link to comment Share on other sites More sharing options...
jimmy34 Posted February 7, 2020 Share Posted February 7, 2020 comment fait lorsque l'on trouve un hôte super pour que dans les parties suivantes cela soit cet hote et non un autre qui heberge notre jeux? Je narrive plus à me connecter sur l'hote avec lequel ma partie na pas laguer Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 8, 2020 Administrators Share Posted February 8, 2020 Vous ne pouvez pas conserver exactement le même hôte à la fin du jeu / serveur et vous ne pouvez pas continuer à partir de ce jeu. La sélection du même emplacement de serveur est la meilleure que vous puissiez faire à cet égard. En théorie, vous pouvez littéralement bloquer chaque serveur, même les autres à cet emplacement, mais ce serait une tâche impossible. - You cannot keep the exact same host as the game/server ends and you're not able to do a continuation from that game. Selecting the same server location is the best you can do in this regard. In theory you could literally block every single server even the other ones in this location but it would be an impossible task. Link to comment Share on other sites More sharing options...
jimmy34 Posted February 8, 2020 Share Posted February 8, 2020 alors enfait je viens de remarquer que c'est vachement aléatoire .. J'étais en mode filtrage avec mon pc de jeux (toujours sur apex legends) et les parties étaient toute laggy. Puis je change en mode spectateur avec l'emplacement de mon domicile en pleine mer avec une distance maximale fixée à 111 klm avec un ping assist de 30 et là, comme par magie, j'ai pu faire 15 parties vraiment parfaite, sans lag. SAUF que, d'un coup sans prévenir, toute les parties sont redevenues toutes laggy ...... Comment expliqué cela? à chaque fois c'est pareil, ça marche pendant quelques heures et après c'est repartis, plus rien ne marche de façon constante, il y a toujours des réglages à tester, à essayer, ça deviens vraiment horrible.. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 8, 2020 Administrators Share Posted February 8, 2020 En mode Spectateur, il n'aurait pas été filtré du tout, mais en supposant que vous ayez conservé le serveur comme vous l'avez sélectionné dans le jeu, il n'y a pas de différence. Si vous avez de bons jeux en mode Spectation et que vous ne l'avez pas fait, cela ressemble plus à un problème de congestion local. - Spectating Mode it wouldn't have been filtering at all but assuming you kept the server the same that you selected on the game then there is no difference there. If you got good games in Spectating Mode and then you didn't then it sounds more like there is a local congestion issue. Link to comment Share on other sites More sharing options...
jimmy34 Posted February 8, 2020 Share Posted February 8, 2020 Les bonnes parties sans lag en mode spectateur n'ont pas durées bien longtemps. Que me conseillez-vous au niveau local à modifier? Pensez-vous que je dois ouvrir les ports NAT sur le routeur netgear pour le jeu apex legends ? Si oui, comment dois-je faire Link to comment Share on other sites More sharing options...
