Trouble with settings for ww2 on xbox1
Set up is xfinity 150/25
I run motorola 6183 modem <netduma<lynksys wrt3200acm
Xb1 is hardwired to netduma
I have an open nat but i cant find a sweet spot for my dsl report i tried all combos and cant seem to get a good buffer rating
Can someone please walk me through settings for xb1 and ww2
Im new to this and get overwhelmed
I mainly play ranked play and if i set geo filter 750 miles around me with ping assist at 80 i cant get a match
check this video out. it is lengthy but concise and goes into every aspect of the R!.  You may be tempted to skip through but don't, trust me it will help you a great deal if you watch it and adjust your settings as you watch :D
sims ultimate netduma guide
https://youtu.be/E_avRb3odVk
B.D
750 miles is a bit small in my opinion, I would go with no less than 1000, depending on where you live?
What is your base ping? you can find out by running a test from 'internet diagnostics' on the Duma. once the test finishes click on 'show details'
Base ping is 19ms
So as i under stand if other people use internet vis upstream router i want device prioritization not the slider adjustments?
Base ping is 19ms
Right - I've switched from slider adjustments to device prioritization and have found success.
Around what percent is a good starting point for a sweet spot i cant seem to find mine i tried 15%down and 20 up
And all around there
I always stick to 70/70
No, 70/70 gives you great balance between amount of bandwidth and minimal ping spikes. It is also the recommended Congestion Control setting by Netduma.
So when people use my internet to watch netflix if i run 70/70 with equal prioritization it wont screw me?
No. If you want to see exactly what is going on with your network I recommend downloading PingPlotter, ping twitter.com, set the interval to 2.5 second, set congestion control sliders to 100%, run the test for a minimum of 10 minutes with no one using your internet. This will let you see the quality of your line. Then run the same test again with the congestion control sliders at 70/70 while you are gaming and others in your house are using Netflix etc and compare the results.
Will do
Ill report back
When i check quality and bloating on dsl reports i have a lot of buffer at 70/70
PingPlotter is a far better way of testing things than DSLReports.
I have tried ping plotter with having consistent results. Im open to advice
Im gunna do a factory rest on the duma
And set up fresh
Someone have a good guideline to setup
The hour video i watched didnt help much
And set up fresh
As above I'd recommend 70/70 Anti Flood for the best balance. It should prevent any bufferbloat from affecting your gaming.
Other than that give these settings a go:
- Reactive Algorithm
- Share excess enabled
- Reset device prioritisation & apply
- Disable IPv6 in WAN, LAN & misc
- Disable deep packet in misc
- Enable turbo mode
- Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds.
- Do a wired speed test from a PC
So far i have had mixed results! 70/70 works now but its not great for me. Also if i play any ranked games its hard to find a lobby 400-900 mile range with 50 ms ping assist . What do i do to turn ping assist off entirely?
If you turn off the geo filter do you find games? If so, how far away from you are the servers and what ping are you getting to them?
Also i have whitelisted my friend but he cannot join my game and doesnt even get my invite.. any help?
It sounds like your friends IP address has changed. You will need to add him to your allow list again.
