Glazeko Posted May 17, 2017 Posted May 17, 2017 So guys my problem got my bad to worse. So my previous problem was my technicolor tc8715d provided by spectrum. The modem was faulty, it was not giving me my full speeds which I thought was 150mbps which I found out I'm supposed to be getting 300mbps download. The problem with the modem was packet loss. I had a sort of a stable ping. I had 4 technicians come here and check my lines replace wires and all that crazy stuff. Finally they replaced my modem with a Arris tg1682g. My Duma doesn't give me 300mbps download I get a max of 80. I have tried using turbo and super turbo mode one at the time and also at the same time and nothing. The modem is in bridge mode, also found out I don't have a stable ping no more. I be getting huge ping spikes out of the blue moon. I don't understand how why the netduma has trouble with most modems. I need your help guys.
Glazeko Posted May 17, 2017 Author Posted May 17, 2017 These are the screen shots with the new modem. Nothing ever comes out stable. Did multiple tests. When I get home I will do some ping plotter tests.
Netduma Staff Netduma Jack Posted May 17, 2017 Netduma Staff Posted May 17, 2017 These are the screen shots with the new modem. Nothing ever comes out stable. Did multiple tests. When I get home I will do some ping plotter tests. Ping plotter tests will definitely help; make sure you run one for a few hours (pinging something like Twitter.com) with your Netduma in the set up and not in the set up - That way you can determine whether the Netduma is causing any issues or not. The results of the Network Diagnostics test usually indicate something wrong with the other equipment or your ISP line rather than an issue with the Netduma itself. The Netduma is compatible with almost all ISP modems / routers. Please post screenshot of ping plotter tests and we'll take a look. Furthermore, make sure you have these settings enabled and let us know if they have an impact on your speed: - Reactive Algorithm - 100% anti-flood - Disable IPv6 in WAN, LAN & misc - Disable deep packet in misc - Enable turbo mode - Enable super turbo mode - Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds. - Do a wired speed test from a PC
Glazeko Posted May 17, 2017 Author Posted May 17, 2017 wow these results are crazy and there is nothing going on in my network.... crazy how a change of modem had a worse impact on my connection....lost for words right now plus im not even getting my 300 speed through the netduma. just from the regular modem.
Zennon Posted May 17, 2017 Posted May 17, 2017 Can you do a ping plotter directly from the new modem please and show us the results, thank you.
RL317 Posted May 17, 2017 Posted May 17, 2017 These are the screen shots with the new modem. Nothing ever comes out stable. Did multiple tests. When I get home I will do some ping plotter tests. Weird but I highly doubt it's a problem with the Netduma, as mine works just fine with my ISP modem. On my new ISP I've never seen anything other than exceptional across the board. I also get my full bandwidth if I'm using 100/100 reactive. Maybe it's the cable you're using between modem and Netduma?
Glazeko Posted May 17, 2017 Author Posted May 17, 2017 So i found out that none of the laptops in my house can't get near 100mbps download via Ethernet cable. I made sure to check on the drivers. i also updated them and still can't get the high speeds. I also purchased 2 new cat6 Ethernet cables and still not getting the my true speeds. One of my laptops supports 5g wifi signal. i tested it with the modem/router combo and i got 180 download speed. had to take the modem off bridge mode to do that test. both laptops cant get near 100 download speed hard wired with neither the modem or the duma. anyways i disconnected everything and ran a ping plotter test straight from the modem and these are the shocking results....This Arris TG1682g its worse than my previous modem, but also the previous modem had issues too. The TG1682g is way worse tho...
Zennon Posted May 18, 2017 Posted May 18, 2017 It is a modem issue, it maybe the chipset it uses and a replacement of the same model may yield the same results.
Netduma Staff Netduma Jack Posted May 18, 2017 Netduma Staff Posted May 18, 2017 So i found out that none of the laptops in my house can't get near 100mbps download via Ethernet cable. I made sure to check on the drivers. i also updated them and still can't get the high speeds. I also purchased 2 new cat6 Ethernet cables and still not getting the my true speeds. One of my laptops supports 5g wifi signal. i tested it with the modem/router combo and i got 180 download speed. had to take the modem off bridge mode to do that test. both laptops cant get near 100 download speed hard wired with neither the modem or the duma. anyways i disconnected everything and ran a ping plotter test straight from the modem and these are the shocking results....This Arris TG1682g its worse than my previous modem, but also the previous modem had issues too. The TG1682g is way worse tho... As Zennon said above, the issue is your new modem rather than how the modem is interacting with the Netduma. Since you've got new wires, that's ruled out as well. You're better off shopping around for a new modem model since that one's giving you some really bad lag spikes.
Glazeko Posted May 19, 2017 Author Posted May 19, 2017 Ok so I got a tp link tc7610. No problem what so ever. Is there any specific setting for the netduma? None of my laptops at home still don't support more than 100mbps wired. Any suggestions for how to seyup my CC. My speeds are supposed to be 300 down and 25 up
Netduma Staff Netduma Jack Posted May 19, 2017 Netduma Staff Posted May 19, 2017 Ok so I got a tp link tc7610. No problem what so ever. Is there any specific setting for the netduma? None of my laptops at home still don't support more than 100mbps wired. Any suggestions for how to seyup my CC. My speeds are supposed to be 300 down and 25 up That's fantastic to hear, I hope you're getting some great gameplay now. I'd recommend these settings (which I suggested earlier): - Reactive Algorithm - 100% anti-flood - Disable IPv6 in WAN, LAN & misc - Disable deep packet in misc - Enable turbo mode - Enable super turbo mode - Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds. - Do a wired speed test from a PC Let us know if you get higher speeds with this setup
Glazeko Posted May 20, 2017 Author Posted May 20, 2017 Ok so ping spikes are more stable but I keep having High ping spikes randomly. Not as often tho. I thought the netduma would resolution this but it doesn't. They still happen.
Administrators Netduma Fraser Posted May 21, 2017 Administrators Posted May 21, 2017 Ok so ping spikes are more stable but I keep having High ping spikes randomly. Not as often tho. I thought the netduma would resolution this but it doesn't. They still happen. I'm going to disagree with my colleague as I think here misread. As your devices network cards won't allow you to get more than 100mbps there is no point having super turbo on which will essentially disable congestion control and therefore not help with spikes. I'd try setting bandwidth to 100 then doing 70/70 anti-flood with console in hyper traffic.
