XSXS Posted November 21, 2016 Posted November 21, 2016 Lost my setting hyper, host filter settings, etc what is up with that?
Slipknot31286sic6 Posted November 21, 2016 Posted November 21, 2016 Happens if u unplug or lose power yup.
XSXS Posted November 21, 2016 Author Posted November 21, 2016 No good, thx. Any thing else i need to reconfigure? My dns settings and a couple of other settings stayed saved
ColonicBoom Posted November 21, 2016 Posted November 21, 2016 I'd go through all of them if I were you.
A7Legit Posted November 22, 2016 Posted November 22, 2016 Lost my setting hyper, host filter settings, etc what is up with that? What you do is set up everything exactly how you like it, I mean everything... Reboot the router via Settings > Miscellaneous. When the router successfully reboots you now can purposefully turn off the Duma from the wall outlet and when you turn it on up to about 6 hours later, those settings you had as you rebooted the Netduma will remain in memory. That's what I do and continue to do.
Administrators Netduma Fraser Posted November 22, 2016 Administrators Posted November 22, 2016 Everybody has already answered your question. I would also recommend saving a profile of your settings and then exporting it so you can import it again. Though definitely set everything up and reboot from misc settings to save.
XSXS Posted November 22, 2016 Author Posted November 22, 2016 Thanks everyone! Great support here! I'll definitely bring doing this in the future!
Netduma Staff Netduma Jack Posted November 22, 2016 Netduma Staff Posted November 22, 2016 Glad we could help we're always here if you need a hand.
