Levesquick Posted October 31, 2016 Posted October 31, 2016 I currently rent a modem router from my isp. This netduma is just a router correct? So to eliminate rental charges I would need to buy a modem too, correct? If so, any recommendations? Thank you in advance
BIG__DOG Posted October 31, 2016 Posted October 31, 2016 it would help if you told us what isp you are using! The netduma is a rounter, yes but it is "not just a router" as it is the software inside that makes netduma great at what it does.
Levesquick Posted October 31, 2016 Author Posted October 31, 2016 Thank you for your response. I'm using metrocast, I was referring to the netduma being a router alone and not a modem as well, is that true? I wasn't trying to say it was just a plain ol router or anything. But I used to have a separate modem and router and now I have one Modem router combo. Anyways, we use two PS4 consoles, two iPhones, an iPod and a tablet almost always. I got the highest package I can get from metrocast being 105 download and I don't remember the upload but on my PS4 even if it's the only thing connected only gets up to about 50mbps not the 105. Always experiencing lag and disconnection issues. Not constantly but frequently. I also called to talk to them about it and they forwarded me to someone who never answered. I'm gonna try again soon but in the meantime I'm researching a better set up and eliminate the rental cost. im assuming I would need a modem as well, I just don't want to buy a modem that would affect the netduma router negatively if possible.
Netduma Staff Netduma Jack Posted October 31, 2016 Netduma Staff Posted October 31, 2016 Hey there, welcome to the forum! You're correct; the Netduma can't be used as a modem, so you'll need to get one of those. No matter what modem you get, however, you'll be able to troubleshoot and improve your games; and all those devices will benefit greatly from the congestion control features. It's not uncommon for Netduma users to encounter issues when setting it up, however; so if you have any problems, feel free to post in our support section and we'll help you out. We can also help you to achieve the best settings for your speeds / modem on here as well.
Administrators Netduma Fraser Posted November 1, 2016 Administrators Posted November 1, 2016 Hey, welcome to the forum! In regards to the Virgin modems Jack referred to I believe he was talking about the line issues with the ISP Virgin media, not their specific modems.
Levesquick Posted November 1, 2016 Author Posted November 1, 2016 Great, I appreciate your input. Does anyone have just a few good cable modem recommendations that they might use with their netduma set up?
fuzzy clam Posted November 3, 2016 Posted November 3, 2016 Welcome to the forums,I'm gonna move your post to the general section so your question will get more views...
