help!!!!
so when i plug my ISP into the Netduma which is the dsl cable. then put my nighthwak modem/router on AP mode and the other wired connections to the Netduma or nighthawk?
the netduma is a router NOT A MODEM so you shouldn't be plugging any dsl cable into it!!!!!....therfore it should be modem then netduma!
Should be one of the following:
Modem > Netduma > Nighthawk
ISP hub > Netduma > Nighthawk
If you setup like below:
Nighthawk > Netduma
You will need to turn the Nighthawk's wifi off or anyone connecting to the wifi will make you lag, as they will be 'outside' of the Netduma's Congestion Control.
