DSL versus Cable
Limagreen
Which do you think is the better connection to have for on line gaming. Particularly Black ops 3.
I have heard that you get lower latency with High speed DSL, and that Cable suffers from higher latency.
Any one had a chance to test both, or know of the technical characteristics, that would favor one over the other?
After 6+ years of cable I finally switched to DSL Uverse and I couldn't be happier, I mean jitter on cable is crazy now on cable my ping was 9 to 10 on dsl is a little bit high 20+. On cable I could never get A+ on  bufferbloat, with dsl is constant A+.
As far as I'm aware, you're always better not using cable (I have cable), unless your alternative is carrier pigeon.
If the question is merely A versus B - Then I would have to say you will PROBABLY find that a DSL, or the new VDSL version that I just found out about and is available all over, is going to be a "cleaner" choice because of the architecture of how they operate.
I have a poor quality Cable line that is just fine for the rest of the household needs.
I just recently had a dedicated gaming line put into my new Command Center (ha ha) and the ping plotter tests on the new line have been night and day difference.
I played several hours of Black Ops 3 as a solo player this weekend (2x Weapon XP sweat-Fest) without the benefit of the Duma and I would say my overall enjoyment was definitely at a higher point than I can remember with this game on the new VDSL
Jitter is a big issue with cable.
Jitter destroys games for the user and the player playing against said user.
Thanks for all the information. I have changed over to DSL now and found a big improvement in my gaming experience.
DSL with the NETDUMA is a winner for sure.
AT&T is putting in gigapower in my neighborhood. Can't wait. See you later Comcast. Woohoo!!!
I just moved to AT&T but still no word of Gigaoower. It is here in some areas but where I live not yet.
IMO no comparison DSL is so much more stable both thru the feel test and documentation by ping plotter.
I use the DSL for a dedicated gaming line and cable for the rest of the house.And we should have gigapower in our neighborhood this fall and yeah I will be all over that shit... :D
