Buster Posted November 17, 2015 Posted November 17, 2015 Hi all, I have recently brought my netduma down to where i live/work during the week, I don't have an ISP hub to plug the netduma into all i have is the Ethernet port in the wall, is there a wiki or anything on how to set up on a LAN network? I have looked but obviously found nothing. Any help is appreciated
Yam Yam Posted November 17, 2015 Posted November 17, 2015 Hello Brown91, Is there any way to get information about the ISP install ? It sounds like a communial connection but can't be sure. Landlords usually have this info. To test it out just plug the ethernet from the wall to port 1(PoE) on the Duma then check for activity.
Buster Posted November 18, 2015 Author Posted November 18, 2015 Hey sorry for the slow reply. basically, I have had the Netduma working now on the connection with Open nat on BO3 and on the xbox so im happy.....Until the connection drops, kicks me off xbox live and when I try to log back in to the providers web page on my laptop it says too many re-direct loops. I have the device on their allowed list which is all i can do ( Cannot put it in DMZ). So im wondering if there are any settings i need to enable/disable in order to make it work for my situation ?
Administrators Netduma Fraser Posted November 20, 2015 Administrators Posted November 20, 2015 I'm not sure anything you change on the duma would affect this or not but I would research your hub model and re direct loops and see if that comes up with any useful solutions
