Alex Posted November 13, 2015 Posted November 13, 2015 I get kicked to lobby and kicked to dash all the time even when I am on my own with or without the Netduma inline. Same here man. I was trying to isolate the problem so I've turned the Duma on and off with no success either way. In my mind that narrows it down to a game/server problem.
Administrators Netduma Fraser Posted November 13, 2015 Administrators Posted November 13, 2015 Okay that does sound like the game, it is early days for them & rest assured we'll be doing all we can on our end as well
DonBoti Posted November 24, 2015 Posted November 24, 2015 Same issue, is not that issue related to the BO3 servers??, because I have the same problem even with R1 disable.
faulko Posted November 24, 2015 Posted November 24, 2015 I disconnected the R1 and sadly my problems are gone... My hitdetection is crisp now. I think party problems occur when geofilter is enabled and your friends are outside the range. Nope all my party players are inside my filter and still can't get on in a party. The game is retarded end of story, i dont know what they are trying to accomplish but it isnt working. 2-3-4 players doesnt matter, (solo, no worries), party up and it drops off the dedi and goes all wonky looking for player hosts, which is terrible btw.
Administrators Netduma Fraser Posted November 24, 2015 Administrators Posted November 24, 2015 Same issue, is not that issue related to the BO3 servers??, because I have the same problem even with R1 disable. If you have the same issues when the Geo is disabled it is a game issue.
DonBoti Posted November 29, 2015 Posted November 29, 2015 Yes Yes I'll give it a try. Thanks mate. I have the same issue, is working better with the strict mode off??, are you playing in good lobbies if strict mode is off? thanks
Zennon Posted November 29, 2015 Posted November 29, 2015 When I get this, myself and my would be party member's reboot the console and then it allows us to party chat and game lobby. In the past backing out until the guy with the two guns screen then back to the mutiplayer screen would work for game lobbies but alas no more.
shantzonpoint Posted December 1, 2015 Posted December 1, 2015 Guys it's not the game. You need to create a port forward on the Netduma. Go to settings/Port Forwarding and create a port forward. Go to this site http://portforward.com/english/applications/port_forwarding/publishers/Activision.htm and select the proper port for your console. I used 3478 as the start port and 3479 and the end port for my PS4. I used 3074 for my XB1 (put 3074 in both start and end ports). Select udp as the protocol. Finally put in the IP address your console uses (PS4 and XB1 were different for me). You can change the rule name to whatever you want. Click "Add Rule", then "Apply", and fire up the game and you'll be all set. The NAT type will be open in game from now on. To find the IP your console uses, on PS4 go to: Settings/Network/View connection status. On XB1 go to Settings/Network/Advanced Settings Before I did this it was a roll of the dice to who I could play with. Since I changed the port forward, it's been flawless. Hope this helps and happy hunting!
feelthefearr Posted January 30, 2016 Posted January 30, 2016 is there already a solution for this? do you really need to forward these ports? or does the duma it self?
nffcbaz72 Posted January 31, 2016 Posted January 31, 2016 It is the game, try playing off peak, its a bit better. Not so much while x xp is going though. Baz.
Zennon Posted January 31, 2016 Posted January 31, 2016 is there already a solution for this? do you really need to forward these ports? or does the duma it self? When you have an open NAT do not worry about ports, they are being forwarded automatically.
feelthefearr Posted January 31, 2016 Posted January 31, 2016 Okay zennon. But why is it the game? Other people in my friend list are playing with 6 man party's.
Zennon Posted January 31, 2016 Posted January 31, 2016 All people trying to party up must either press the xbox button start a new game in your collection then restart bops 3 or go back to the title screen with the burning 3 and try again.
feelthefearr Posted January 31, 2016 Posted January 31, 2016 We all play on the ps4. That does not work. I dont know what i have to do. Nothing works. When i play alone or with one other friend there are no problems
