Janco Posted September 24, 2015 Posted September 24, 2015 The issue is simple. My netduma is unusable with gears. To the point where its unplugged and not being used. If I use my isp router then I have no problems. Basically after a few games using the duma, it disconnects never to return. Usually requires a manual power cycle as it becomes inaccessible via software / browser. Could you please recommend the perfect wireless settings to avoid this. I'm using the latest firmware and a multi adaptor plug, deep packet: on ipv6: off cookies: off work arond : on cloud: both ticked No filtering, no congestion. Just trying to use the duma wirelessly. When is the next firmware coming?
Netduma Staff Netduma Crossy Posted September 24, 2015 Netduma Staff Posted September 24, 2015 What modem are you using with the Netduma?
Netduma Staff Netduma Crossy Posted September 24, 2015 Netduma Staff Posted September 24, 2015 If you don't play the game do you get the problem?
Zennon Posted September 24, 2015 Posted September 24, 2015 As you are using WiFi you may need to un-tick the wifi workaround in misc settings of the duma .
Administrators Netduma Fraser Posted September 24, 2015 Administrators Posted September 24, 2015 Couple of things, If you're trying to use the Geo-filter with GoW, it's not completely optimised. I'd recommend ticking cookies to save settings. Try turning wifi workaround off, and finding the least congested channel and using that also.
Zennon Posted September 24, 2015 Posted September 24, 2015 how-to-find-the-best-wi-fi-channel-for-your-router-on-any-operating-system
