Help fix my lag
Hi could someone help me with this router i bought it 2 weeks ago and i have been having trouble for the past two weeks now i purchased it to "dominate lag" but my lag is worse now idk why i tried preemptive and reactive and i always feel like im a second or two behind it also take me a ridiculous amount of bullets to kill someone i have congestion control percentages both to 70% i tried moving it up and down and it seems better when it is lower, i have my geo filter usually around 500km-1300km ( i live in the us on the eastcoast ny) ping assist value usually 20-30 and my internet speed is 50download 25upload i updated the bandwith as well and i play on a monitor sorry for the long read but ive been having a frustrating gaming experience and i just want to solve it any help will be appreciated
Welcome to the forum, having issues can be frustrating but lets try to point point the problem for you. What game are you playing and for what system or computer?
You posted great starting information! Could you do a Internet Diagnosis from the Netduma GUI and post the results?
My console is the ps4 and i tried to play every cod from mw1 on ps3 to aw on ps4 (Also im very sorry for the multiple pics im on my phone atm)
Hi Souaibou, welcome to the forum :)
Could you post the rest of the information from here please. Your base ping from above is very good so you shouldn't be lagging.
Yes buddys this is where you schould post those pictures and welcome to the DUMA ARMY.
Would be helpfull if you could poste the full pictures just like in that thread.
Your base ping is great, you should be air walking around people. Can you also post a picture of your mic settings. I want to see what boxes you have checked.
Miscellaneous, i also tried turning upnp fowarding and deep packet on idk the gameplays were inconsistent i would do ok in few and great in others but i always felt like they eat bullets and they shoot before they even come around the corner, oh and i tried bleeding edge it kinda help but the lag was still there shoot first no hit markers die first
On the Host filtering section it should be right under Geo filter. Check the pic. If not your are not on the latest update.
At the bottom of screen what is your debug version? It should be 1.03.4.  If you need to upgrade follow this link's instructions exactly when and if you upgrade. Thanks.
http://wiki.netduma.com/doku.php?id=manual_update&s[]=upgrade
Maybe that was my problem it says im on the latest update but apparently im not so i will do more testing with the new update
I think your problem lies with your old router/modem. I'm not a network specialist but I've messed with router settings for countless hours. I bought my Netduma two days ago and nothing I did would eliminate the lag. I put my Netduma IP in the old router (Netgear) reserve and DMZ'd but still no use. It wasn't until I ticked a secured NAT (not OPEN) and disabled my SIP ALG that I completely eliminated the lag. I also Port forwarded on the Netduma and unticked Upnp. Hope this helps :)
No problem.  This is a problem that the administrators are going to be fixing.  The only way to update now is with manual update.  Under Upgrade and you are running the latest firmware notice is not functioning fully.  Sorry for any inconvenience. Happy gaming.
@Multifeed i dont think so and i only used to use my cable providers router and modem i had superb connection but there would be times when i connected to people in far away lobbies like france or something due to advanced warfare's sbmm thus creating lag so i bought this router so i can play with people within my area and just replaced my old router i never had problems in ghost and my ping is 10ms to my provider
Well at least there is helpful mods like yourself. I just did the upgrade everything went smooth, thanks. Is there an area on the forum where I could get the Miscellaneous settings? I'm having good connection now that I disabled my old router firewall but I still want to make sure I'm using the optimal settings. My connection is below 5mb just in case that matters with Misc. settings. Thanks for any help you can provide.
@Souaibou running a speed test to your ISP servers is always going to be the fastest because it is usually test the closest servers. To get more accurate results, go to speedtest.net or pingtest.net and test on a server that is closest to the furthest location for your Geo Server range. I usually test to New York or Canada just to see the highest possible ping as I have my Geo Filter set to the entire U.S. and live in Texas.  I get very little lag even in 100ms lobbies, at least on MW3 which has the worst lag comp ever.
If you follow the instructions in the following link and only change the settings from default if instructed you'll have the most optimum setup with the Netduma :) http://wiki.netduma.com/doku.php?id=fine_tune_netduma
You have 20ms of jitter in your duma net diags , for me that would be unplayable and unexceptable.
Please do further tests to see if that was a one off or not , perferable at peak times so after dinner from 6-7pm onwards.
You can also use Ping Plotter To help diagnose a jitter issue.
Type 8.8.8.8.8 in the bar and set to update every second and trace.
I used to have 2-3ms of jitter on my old set up how do i fix this?
Actually, when I calculated it (using the method ping plotter uses) you only had 4.603ms of jitter which isn't bad at all. So I'm not sure if there is anything to fix :)
I see 22 ms jitter
Lowset 10ms  highest  32ms via a duma diags.
without seeing te ping plotter output , no one csn say what the results hold.
please run at peak times :)
I see 22 ms jitter
I don't think thats how jitter is calculated. I could only find one place that explained how to do it and that was ping plotter who said to calculate the difference between each of the pings then get an average of that. It's explained in the link I linked :)
