Tua PR Posted September 29 Posted September 29 Hello, Netduma team! As a huge fan, user, and beta tester, I’d like to suggest a native Netduma Mesh system for your next hardware release. In fact, I recently had to disconnect my Netduma R3 because I have a 1 Gbps up/down connection, and hardware limitations prevented me from utilizing the full speed. On top of that, I live in a two-story apartment with heavy interference from neighboring Wi-Fi networks, and a single R3 just can't get the signal everywhere. A native Mesh system would completely solve these issues. It would allow users with high-speed connections to achieve full coverage across multiple floors and overcome intense interference—all while maintaining unique DumaOS features (like Geo-Filter and Congestion Control) across every node. It would combine your gaming software with the reliable coverage and performance that modern households urgently need! Redflame 1
Administrators Netduma Fraser Posted September 30 Administrators Posted September 30 That would be really cool but it would involve a lot of work in an area we've not really touched before, perhaps once this big feature update is done we'll have more time to look into things like this Redflame and Tua PR 2
Newfoundland Posted September 30 Posted September 30 Trouble is with a mesh what makes you think your phone will swap, they work by signal strength and in a small apartment mesh systems don’t work well because phones will tend to stick to a single access point. WiFi 6 should have helped due to the BSS Coloring, WiFi 6 was built for congested areas, you would need to ask the developers what standards within WiFi 6 they support on the R3.
Tua PR Posted September 30 Author Posted September 30 11 hours ago, Newfoundland said: Trouble is with a mesh what makes you think your phone will swap, they work by signal strength and in a small apartment mesh systems don’t work well because phones will tend to stick to a single access point. WiFi 6 should have helped due to the BSS Coloring, WiFi 6 was built for congested areas, you would need to ask the developers what standards within WiFi 6 they support on the R3. I get your point about sticky clients in small spaces, but my apartment layout is a bit of a nightmare for RF. I live in Puerto Rico, and here, buildings are entirely made of thick reinforced concrete with heavy steel rebar inside. Concrete and steel are basically an absolute dead end for Wi-Fi signals. Also, the layout is quite unique (The ceiling of my living room is my neighbor's second floor, and my bedrooms are underneath theirs—and vice versa... It's weird.). A single router, even with Wi-Fi 6 BSS Coloring, simply cannot punch vertically through that thick reinforced concrete slab to reach the rooms. To solve this, I actually had to switch to a Wi-Fi 7 mesh system (Deco BE10000). The nodes communicate perfectly and my phone drops and swaps flawlessly between floors. That's exactly why I know a native DumaOS mesh solution would be a massive lifesaver for complex architectural layouts like this!
Tua PR Posted September 30 Author Posted September 30 15 hours ago, Netduma Fraser said: That would be really cool but it would involve a lot of work in an area we've not really touched before, perhaps once this big feature update is done we'll have more time to look into things like this Thank you so much for replying! I completely understand that developing it from scratch involves a massive amount of back-end work, especially since DumaOS has traditionally been focused on single gaming routers. It's great to hear that it's at least a cool concept on your radar! I'll be looking forward to that big feature update you guys are working on right now. Hopefully, once the dust settles, a native mesh system can be explored down the road. Keep up the awesome work with the updates! Netduma Fraser 1
Newfoundland Posted October 3 Posted October 3 On 10/1/2026 at 12:35 AM, Tua PR said: I get your point about sticky clients in small spaces, but my apartment layout is a bit of a nightmare for RF. I live in Puerto Rico, and here, buildings are entirely made of thick reinforced concrete with heavy steel rebar inside. Concrete and steel are basically an absolute dead end for Wi-Fi signals. Also, the layout is quite unique (The ceiling of my living room is my neighbor's second floor, and my bedrooms are underneath theirs—and vice versa... It's weird.). A single router, even with Wi-Fi 6 BSS Coloring, simply cannot punch vertically through that thick reinforced concrete slab to reach the rooms. To solve this, I actually had to switch to a Wi-Fi 7 mesh system (Deco BE10000). The nodes communicate perfectly and my phone drops and swaps flawlessly between floors. That's exactly why I know a native DumaOS mesh solution would be a massive lifesaver for complex architectural layouts like this! The R3 was never the greatest at distance compared to other manufacturers. You would need to be wired throughout and need granular control, that’s a bit more than most domestic routers support. My old Netgear RX120 had so much more coverage, just better hardware. You would benefit from a little wired Unifi system.
Tua PR Posted October 3 Author Posted October 3 6 minutes ago, Newfoundland said: The R3 was never the greatest at distance compared to other manufacturers. You would need to be wired throughout and need granular control, that’s a bit more than most domestic routers support. My old Netgear RX120 had so much more coverage, just better hardware. You would benefit from a little wired Unifi system. Trust me, I would love a wired setup, but that's a nightmare over here! Most houses in Puerto Rico were built around the 1950s for hurricane protection, so everything is solid reinforced concrete. There are no drywall channels or conduits to drop cables through. Making it wired would literally mean drilling and breaking into solid concrete walls, which is just not an option for me.
Krush Posted October 3 Posted October 3 Salut @Tua PR J'ai également eu ce soucis dans un maison ancienne, j'ai réussi à câbler l'ensemble des pièces en RJ45 via le réseau électrique et en surélevant les planchers pour faire passer les câbles au sol.
Tua PR Posted October 3 Author Posted October 3 10 minutes ago, Krush said: Salut @Tua PR J'ai également eu ce soucis dans un maison ancienne, j'ai réussi à câbler l'ensemble des pièces en RJ45 via le réseau électrique et en surélevant les planchers pour faire passer les câbles au sol. Oh, merci pour l'idée ! That sounds like an amazing project for an old European house, but raising the floors?! Mon dieu, I am way too poor for that kind of extreme home makeover! 😭😂 Krush 1
Krush Posted October 3 Posted October 3 13 minutes ago, Tua PR said: but raising the floors?! Si ton sol est sur une dalle béton, tu peux faire un parquet en bois par exemple et faire filer les câbles entre les supports du parquet au sol, tu fais une petite saigné dans les murs pour installer les prises RJ45. Hihi, y a un peu de travaux mais c'est jouable ! Tua PR 1
Newfoundland Posted October 4 Posted October 4 20 hours ago, Tua PR said: Trust me, I would love a wired setup, but that's a nightmare over here! Most houses in Puerto Rico were built around the 1950s for hurricane protection, so everything is solid reinforced concrete. There are no drywall channels or conduits to drop cables through. Making it wired would literally mean drilling and breaking into solid concrete walls, which is just not an option for me. I know how it is we have a place in The Philippines and we have built in typhoon alley, it’s wrapped concrete with rebars just like yours. The only advantage was I was able to plan for solar integrations and network but even the basic PDLT routers work fine here. Mesh will not work well in your case.
Krush Posted October 4 Posted October 4 22 minutes ago, Newfoundland said: basic PDLT routers PDLT c'est un FAI ?
Newfoundland Posted October 4 Posted October 4 3 hours ago, Krush said: PDLT c'est un FAI ? Yes it’s an isp which supplies generic routers. Thanks to the EU many grants have been supplied to enable fibre throughout many areas in the Philippines right into remote areas. Typical build is hollow core with rebar and then a cement wrapping. My better half gets 400 up and down in a rented province house for the grand sum of 300 peso a month, which at present rates is around 4.26 euro a month.
Tua PR Posted October 4 Author Posted October 4 23 hours ago, Krush said: Si ton sol est sur une dalle béton, tu peux faire un parquet en bois par exemple et faire filer les câbles entre les supports du parquet au sol, tu fais une petite saigné dans les murs pour installer les prises RJ45. Hihi, y a un peu de travaux mais c'est jouable ! Oh, I see! Got it. Still, it's a big project, and my wife would kill me if it didn't look "aesthetically beautiful." But thanks for giving me some alternatives.
Tua PR Posted October 4 Author Posted October 4 4 hours ago, Newfoundland said: I know how it is we have a place in The Philippines and we have built in typhoon alley, it’s wrapped concrete with rebars just like yours. The only advantage was I was able to plan for solar integrations and network but even the basic PDLT routers work fine here. Mesh will not work well in your case. It’s amazing how we share the exact same structural challenges from completely opposite sides of the world! Concrete and storm-ready builds are definitely a unique beast. However, a mesh setup actually does work perfectly in my case. I'm currently using a Wi-Fi 7 system, and because the concrete walls degrade the signal so drastically, it actually forces my phone to drop the weak connection and swap to the closest node instantly without getting "stuck". My current mesh completely solved my coverage and roaming issues. That's exactly why I brought up this suggestion—since multi-node hardware fixed my concrete apartment problem, having that same reliable coverage natively powered by DumaOS's gaming tools would be the absolute dream setup!
Newfoundland Posted October 4 Posted October 4 What is the throughput on each access point? I can’t personally see them developing a mesh, they have never branched out beyond gaming routers sadly. WiFi 7 promised a lot but it can’t escape physics and restraints of WiFi. MLO is a mess and very few clients apart from the obvious phones. Until IoT that make up the vast majority of clients change we see much promise much but offer little sadly.
Tua PR Posted October 5 Author Posted October 5 8 hours ago, Newfoundland said: What is the throughput on each access point? I can’t personally see them developing a mesh, they have never branched out beyond gaming routers sadly. WiFi 7 promised a lot but it can’t escape physics and restraints of WiFi. MLO is a mess and very few clients apart from the obvious phones. Until IoT that make up the vast majority of clients change we see much promise much but offer little sadly. My internal transfer speed between nodes hits between 800 and 850 Mbps, even through the concrete slab; it’s more than enough for my 1 Gbps fiber connection and works perfectly for gaming. I use Wi-Fi SweetSpots and the Deco app to monitor it, and honestly, the dedicated wireless backhaul handles the environment fantastically. You’re absolutely right that MLO and Wi-Fi 7 are still in their infancy for mainstream IoT devices, but since my main gaming rig and phone support them, they do the job where it matters most. I know it’s unlikely Netduma will venture into multi-node hardware, but hey, the suggestion box is there for a reason! Thanks for the chat and the feedback! Newfoundland 1
Newfoundland Posted October 5 Posted October 5 This is my personal view but I don’t think they branched out, still using cache on the web browser, it’s really old tech. The Internet has moved on and so is networking And that’s why companies like UniFi who are not that old, 2005 if mem serves me well but look how they have grown. I can see company house reports because in the UK companies have to publicly show reports. They could’ve easily produce a gaming router, normal routers and grown and developed into more hardware and different market segments. My personal point of view and the again is my personal point of view the hardware is lacking and it’s outdated software. If I look in the Philippines the majority game on mobile phones. The majority use a generic router. A Niche market is risky, I just wish they had branched out more in the early days. and here’s the thing you can walk into an airport go onto the public Wi-Fi and make perfectly stable video calls, and that’s with thousands of people using that network. networking has moved on a great deal, I just wish they had moved on with it. I believe they could’ve had a decent company covering different aspects of networking. That’s my personal point of you and it would’ve been great to see a British company competing against other companies. I’m still in the U.K. at the moment, flipping between countries and I talk to better half with no latency issues and she sat in a very basic provincial house using a generic router. It’s not even set up in a good place it’s in the corner of the house and next to it is the solar system which I put in. Tua PR 1
