Administrators Netduma Fraser Posted February 29, 2024 Administrators Posted February 29, 2024 Congestion Control for Upload should definitely be lowered - I think that will help you. Disable GeoLatency Disable PingAssist (set it to 0,0) Enable Strict Mode Disable Fast Search Then restart game or wait 10 minutes (in the lobby in the game). If that doesn't work, reboot PC/Console and it should work then. For consoles it is normal that is adds that way. You are on an older version, this is the latest: https://forum.netduma.com/topic/53938-new-r3-firmware-4041/ Tony 1
Tony Posted February 29, 2024 Author Posted February 29, 2024 Merci beaucoup Fraser pour ta réponse, la seule chose que je n’avais pas faite était de désactiver le Geo Latency. Pour l’upload a combien conseilles tu de mettre ? 70% d’upload ?
Administrators Netduma Fraser Posted February 29, 2024 Administrators Posted February 29, 2024 70% is our recommended starting point, see how that is for you and then adjust from there Tony 1
Tony Posted February 29, 2024 Author Posted February 29, 2024 Merci beaucoup Fraser 🙏 Netduma Fraser 1
Tony Posted February 29, 2024 Author Posted February 29, 2024 Fraser 😅 juste une petite question, mon upload est très bas de base : environ 30mbps donc si je place le congestion control à 70% mon internet est très lent. Dans le menu Internet de la Xbox, je n’arrive même pas à avoir les donnés de connexion ( type de nat, connexion au services Xbox ) car je pense que mon upload est trop bas. Je laisse quand même à 70% pour l’upload juste le temps de jouer et je replace à 100% quand j’ai finis ou bien je replace à 100% tout le temps ? Cela peut il avoir un mauvais impact en jeu ou au contraire ça pourrait l’améliorer ?
Administrators Netduma Fraser Posted February 29, 2024 Administrators Posted February 29, 2024 30 is absolutely plenty - gaming only uses around 1Mbps at most - you could set it to Auto so it only applies when you're gaming Tony 1
Tony Posted February 29, 2024 Author Posted February 29, 2024 Ok thank you again Fraser ✌️ Netduma Fraser 1
Tony Posted March 2, 2024 Author Posted March 2, 2024 Bonjour à tous, Comme indiqué dans mes messages précédents, je suis sous l’ancienne version du DUMAOS, est il nécessaire de faire la mise à jour ? Cela peut il améliorer mon expérience de jeu ? Merci à tous
Administrators Netduma Fraser Posted March 2, 2024 Administrators Posted March 2, 2024 There will be fixes/improvements so yes it could definitely help to upgrade to .41 Tony 1
Tony Posted March 5, 2024 Author Posted March 5, 2024 Bonjour à tous, Je continue toujours à essayer de régler au mieux mon Netduma 😅 et j’aurai voulu savoir si il était important de changer les DNS de la console et également dans le modem du FAI ? Si oui quel DNS est plus performant : Google ou Cloudflare ? Et faut il mettre le même DNS dans la console et le modem ? Car j’ai vu que certains avait un DNS pour le modem et un autre différent pour la console . Merci beaucoup à tous 🙏
Administrators Netduma Fraser Posted March 5, 2024 Administrators Posted March 5, 2024 2 hours ago, Tony said: Bonjour à tous, Je continue toujours à essayer de régler au mieux mon Netduma 😅 et j’aurai voulu savoir si il était important de changer les DNS de la console et également dans le modem du FAI ? Si oui quel DNS est plus performant : Google ou Cloudflare ? Et faut il mettre le même DNS dans la console et le modem ? Car j’ai vu que certains avait un DNS pour le modem et un autre différent pour la console . Merci beaucoup à tous 🙏 DNS won't do anything for your gaming but you would set it on the router/modem, no need to do it on the console. Cloudflare is very good. Tony 1
Tony Posted March 5, 2024 Author Posted March 5, 2024 Ok Fraser thank you ! En ce qui concerne le Steady Ping j’ai vu qu’il augmenté le ping. Je dois le conservé actif ou inactif ? Etant donné que j’ai déjà du ping sur les servers proche de chez moi, j’ai peur que ça augmente trop mon ping. Et autre question stp, dans le Geo Filter je ne peux pas sélectionner le jeu auquel je joue pour ma console. « Selected Game » et « All console games » je ne peux pas y accéder. C’est une option uniquement pour le PC ? Et une autre question stp 😅 dans la partie « Setting / DHCP » je dois mettre ma console ? Et aussi dans la partie « Setting / Port Forwarding », je dois activer la DMZ pour ma console ? J’ai vu sur le forum que quelqu’un conseille de mettre les ports suivants : 1-65535 en UDP et TCP ( bandwidth reservation ) Est ce que cela pourrait m’être utile Fraser ? Merci d’avance Fraser et désolé pour toutes mes questions 😅😅 Anonymous 1
Administrators Netduma Fraser Posted March 5, 2024 Administrators Posted March 5, 2024 Steady Ping raises your ping to absorb spikes/fluctuations in the ping, if this doesn't happen to you then you can disable it. Yes you only pick specific games for PC. You don't need to do any of the other things you mentioned Tony 1
Tony Posted March 12, 2024 Author Posted March 12, 2024 Bonjour à tous , Je fais juste une petite mise à jour après 2 semaines d’utilisation et je dois dire que dans mon cas le Netduma a complètement changé mon expérience de jeu. J’avais un Bufferbloat de C avant et maintenant grâce au routeur je suis passé à A+. Ma hit detection est donc devenue bien meilleure. Je me localise sur le serveur le plus proche de chez moi pour avoir le plus petit ping et les parties sont devenues bien plus fluides et je reprends enfin du plaisir à jouer ( MW3 sur Xbox series X ). De part ma localisation particulière c’est sûrement la raison pour laquelle le Netduma a tout changé ! Je remercie également Fraser pour toutes ses réponses rapides et sa disponibilité ainsi que tous ceux qui m’ont aidé à configurer le routeur. Je suis certain que le Netduma permettra à tout le monde d’avoir une meilleure expérience gaming bientôt ! Bon jeu à tous , Tony 😎✌️ Krush 1
Administrators Netduma Fraser Posted March 12, 2024 Administrators Posted March 12, 2024 That is brilliant to hear, thank you for getting back to us with an update on how you are doing! Tony 1
Tony Posted March 17, 2024 Author Posted March 17, 2024 Bonjour à tous, Une petite question, sur ma console et au niveau de L’UPNP du Netduma, le port ouvert est le 50729 maintenant au lieu de 3074 ! Est ce normal ? Et comment le changer svp ? Merci à tous, Tony
Administrators Netduma Fraser Posted March 17, 2024 Administrators Posted March 17, 2024 The port can change based on what the console asks for, on the Xbox you can set the port it uses in Network Settings Tony 1
Tony Posted March 28, 2024 Author Posted March 28, 2024 Bonjour @Netduma Fraser 👋, Serait il possible d’avoir une mise à jour des serveurs en Floride svp ? Il m’arrive de mettre environ 40 minutes pour trouver une partie 😅 Serait il possible de rajouter des serveurs en Floride / Miami ? Merci d’avance, Tony 😎✌️
Administrators Netduma Fraser Posted March 28, 2024 Administrators Posted March 28, 2024 We can take a look, do you get a fast game there without the Geo-Filter enabled?
Tony Posted March 28, 2024 Author Posted March 28, 2024 @Netduma Fraser Même sans le geo filter activité je mets beaucoup de temps pour trouver une partie ! Merci pour votre aide 🙏
Administrators Netduma Fraser Posted March 29, 2024 Administrators Posted March 29, 2024 18 hours ago, Tony said: @Netduma Fraser Même sans le geo filter activité je mets beaucoup de temps pour trouver une partie ! Merci pour votre aide 🙏 Likely the servers there are not always available then as without the Geo-Filter you're not restricting the search!
Tony Posted March 29, 2024 Author Posted March 29, 2024 @Netduma Fraser 👋 Je comprends mais la les serveurs en Floride ne sont pratiquement jamais disponible. Strict mode activé ou strict mode désactivé ! Serait il possible de faire une mise à jours des serveurs ?
Administrators Netduma Fraser Posted March 29, 2024 Administrators Posted March 29, 2024 54 minutes ago, Tony said: @Netduma Fraser 👋 Je comprends mais la les serveurs en Floride ne sont pratiquement jamais disponible. Strict mode activé ou strict mode désactivé ! Serait il possible de faire une mise à jours des serveurs ? The Geo-Filter shows you what servers are available, we don't need to add anything for you to connect to them, unless they are mislocated - in which case you would still connect to them with it disabled we can't force you somewhere that is unavailable to play on
Tony Posted March 29, 2024 Author Posted March 29, 2024 @Netduma Fraser Ok I understand ! Thank you for the precision Netduma Fraser 1
