Hello, I vote contact because I noticed a problem (which I already had on netduma R2) when I activate geofilter I switch to nat not available and when I deactivate I go back to nat open. On my internet operator it's in dmz, is there anything I'm doing wrong? Or is it just a bug known to the developers? Sincerely Julien
Do you see any servers being blocked on the geo-filter when you check the NAT? If you do could you provide its ID so the team can whitelist it?
As above that'll be the cause. However, you will still have an Open NAT, the Geo-Filter won't prevent that, it's likely just blocking the server responsible for checking the NAT status
Okay, so for you, it doesn't look very serious? And I had another question: why do I sometimes go to servers outside the geofilter zone with ping at 120ms even manually blocked?
@julienFR have you tried pollutionblues suggestion? If you can see the server reporting on NAT status on your Geofilter you should be able to allow it and that might resolve your issue.
1 hour ago, julienFR said:
Too strong boys your solution worked, on the other hand the server concerned has a wild ping how does it do 250ms?
  • Disable GeoLatency
  • Disable PingAssist (set it to 0,0)
  • Enable Strict Mode
  • Disable Fast Search
Then restart game or wait 10 minutes (in the lobby in the game). If that doesn't work, reboot PC/Console and it should work better then.
2 minutes ago, julienFR said:
Thank you Fraser I will try this and I will keep you informed, about this will there be any changes to come for the geofilter?
Yes we'll continue to improve the Geo-Filter
1 hour ago, Damiano Calafiore said:
@Netduma Fraserse disabilito la geolatenza su xbox,si chiude il nat ,oppure certe impostazioni non vanno!!
Disabling the Geo-Filter wouldn't affect the NAT Type at all, if anything it would do the opposite, what other issues are you seeing when disabling?
Ho provato a disattivarlo e poi accendere il dispositivo dopo 10 ,minuti ,su impostazioni di rete di xbox,il nat continua a caricare ,il test di xbox non funziona,i geofiltri rilevano con difficoltà i server disegnati ,è capitato pure che si chiudesse l app del gioco ,disattivando noto un peggioramento !!
In the Xbox network settings make sure the port being used is 3074 then reboot the console and see if it works better after that please
