Xr1000 problems
I have a number of problems...
1- Geo filter / the geo filter was not able to access the cloud, please ensure you have a active Internet connection?
2- congratulation control / when I run the auto set up test it doesn't show no readings
 3- connection benchmark / when I run the test its showing no readings
I'm connected to the Internet and if I do a speed test on the Web I'm getting over 500mb download
Have you tried to resync cloud? Or reset router?
maybe disconnect power from both modem and router wait a minute or two then connect power to the modem wait until the modem stabilizes back on and then power up the router. Try this and see if everything balances out first before resetting things.
Welcome to the forum!
As mentioned above, please go to the three-line menu in Geo-filter and hit 'Resync cloud'. Do you still get the same error?
Can you show screenshots of exactly what you're seeing in Congestion Control and Connection Benchmark?
I've done resync cloud and think that's solved that.
However.... Qos isn't auto testing and connection benchmark is just loading as if it is doing the test but doesn't show anything
#help
That's odd, can you open an incognito/private window in your browser and check if the behaviour is the same there?
If it is, can you download a copy of the log file from System Information -> Logs and send it over to me?
I've just tried chrome Web browser and it works fine... I was using opera GX when I had the problem
It may be that Opera is forcing a connection to the interface using HTTPS so if you can disable that then it may then work on Opera
