morph1kx Posted July 13, 2022 Posted July 13, 2022 (edited) Hello. Since my R2 replacement i constantly get packet loss and ping spikes in various games (COD BF5 Fortnite Apex Legends).I get packet loss either with Lan or Wifi. Multiplayer games are almost unplayable because of disconnects. At first i tought its game servers or my ISP.Hovewer there are things i tried already: Ethernet cable replacement Updated Firmware Different LAN Cable Disabled IPv6 Adjusted QoS sliders from 10 to 100, Disabled QoS Different Multiplayer games Disabled Geofilter Sync Cloud Multiple factory resets Changed WiFi settings to different channels (Automatic too) Manual Dns settings in R2 and in Game consoles (happening in ps4 and xbox sereies x) Disabled Protection Nothing helped, till i tried different router (TP Link).And i realized - this problem is happening only with R2. 2 different routers that i tested,dont have problems with packet loss and ping spikes.Everything is stable even withous QoS My firmware is 3.2.453 (This problem started with stock 3.0.207i firmware. Basically when i got my R2 replacement.) My speeds from ISP is Fiber 1000/1000 .In reality 800-900/850-900. I dont know what to do next. Please help me with this problem... Edited July 13, 2022 by morph1kx
Netduma Liam Posted July 13, 2022 Posted July 13, 2022 Just to clarify, have you reset since the upgrade to the latest firmware version? If not, could you please do so. Can you also answer a few questions for us: Are ALL devices on the network connected via the R2? Have you got any custom rules configured in Traffic Prioritisation? If so could you please share them? If not, is the DumaOS classified games rule detecting traffic while you're playing? This is indicated by a red light on the rule, and the packet counters increasing. What's the make and model of your modem?
morph1kx Posted July 13, 2022 Author Posted July 13, 2022 30 minutes ago, Netduma Liam said: Just to clarify, have you reset since the upgrade to the latest firmware version? If not, could you please do so. Can you also answer a few questions for us: Are ALL devices on the network connected via the R2? Have you got any custom rules configured in Traffic Prioritisation? If so could you please share them? If not, is the DumaOS classified games rule detecting traffic while you're playing? This is indicated by a red light on the rule, and the packet counters increasing. What's the make and model of your modem? Hello.Yes, i factory reset R2 after firmware version(3-4 times) 1.Yes all devices connected to R2, i also tried reset and connect only 1 device (Xbox). 2.No custom rules right now, i tried to add game console but no improvements. 3.Yes,DumaOS detecting traffic from game console and classified games. 4.I dont have acces to modem or any information about model(so i cant access modem interface).I think it is pure modem. Also as far as i know this is happening with replacement.When i had my first R2 there was not any packet loss and ping spikes
Netduma Liam Posted July 14, 2022 Posted July 14, 2022 Thanks for that, could you please disable the DumaOS classified games rule, then add a new one. In the new rule, select your games console as the device and 'Games Console' as the service when prompted. After that, set Congestion Control low, down to about 40% maybe. Then set it to always. After doing this, click 'Reset allocation' on Bandwidth allocation just to be safe. Then, play some games and see how it feels. A couple of follow up questions: Do you know if you require PPPoE, VLAN or DHCP identifiers to get a connection to the internet? Are you using Geo-filter? If so could you share your configuration with us?
morph1kx Posted July 14, 2022 Author Posted July 14, 2022 5 hours ago, Netduma Liam said: Thanks for that, could you please disable the DumaOS classified games rule, then add a new one. In the new rule, select your games console as the device and 'Games Console' as the service when prompted. After that, set Congestion Control low, down to about 40% maybe. Then set it to always. After doing this, click 'Reset allocation' on Bandwidth allocation just to be safe. Then, play some games and see how it feels. A couple of follow up questions: Do you know if you require PPPoE, VLAN or DHCP identifiers to get a connection to the internet? Are you using Geo-filter? If so could you share your configuration with us? 1.Automatic DHCP i think.I dont need to put something manually 2.My geofilter settings below. I also tried Ocean method with ping assist and disabling geofilter I will try QoS 40 percent with game console prioritization
Administrators Netduma Fraser Posted July 14, 2022 Administrators Posted July 14, 2022 That looks all good there, let us know how you get on with those QoS settings, also where are you measuring/seeing the packet loss and spikes?
morph1kx Posted July 14, 2022 Author Posted July 14, 2022 24 minutes ago, Netduma Fraser said: That looks all good there, let us know how you get on with those QoS settings, also where are you measuring/seeing the packet loss and spikes? In cod, when gameplay stutter i check ping in game and from 30-40 it up to 110-200 for a second. Also game detect packet loss.In BFV my ping goes from 30-33 to 70-80 and if i enable net graph i can see big ammount of jitter. It feels like constant disconnection for half a second.Also i tried bufferbloat test from waveform (tested on xbox) and my download bufferbloat very low with any amount of QoS.However upload bufferbloat sometimes show in 200-300ms range with jitter 300-1000.With other routers i have Grade A with low jitter.With my R2 i struggle to get even B. For examle with TP-Link (without any QoS enabled) i dont get so ammount of spikes and high ping on bufferbloat test. Still testing your QoS recommendations...
Administrators Netduma Fraser Posted July 14, 2022 Administrators Posted July 14, 2022 I'd suggest using this guide and while saturating your connection with downloads/streams experiment with different percentages and see what brings it down the most http://support.netduma.com/en/support/solutions/articles/16000074717-how-to-test-your-internet-ping
morph1kx Posted July 14, 2022 Author Posted July 14, 2022 2 hours ago, Netduma Fraser said: I'd suggest using this guide and while saturating your connection with downloads/streams experiment with different percentages and see what brings it down the most http://support.netduma.com/en/support/solutions/articles/16000074717-how-to-test-your-internet-ping I dont think QoS settings are helping.I still get ocasional packet loss and ping spikes.Even when playing wired.Wireless gaming expirenece is terrible .
Administrators Netduma Fraser Posted July 14, 2022 Administrators Posted July 14, 2022 What are the results like from PingPlotter? What percentages have you tried?
morph1kx Posted July 15, 2022 Author Posted July 15, 2022 14 hours ago, Netduma Fraser said: What are the results like from PingPlotter? What percentages have you tried? I have tried qos sliders from 5 to 100. Ping spikes and packet loss happening even on 5 percent qos setup.Wired or wireless.
Netduma Liam Posted July 15, 2022 Posted July 15, 2022 2 hours ago, morph1kx said: I have tried qos sliders from 5 to 100. Ping spikes and packet loss happening even on 5 percent qos setup.Wired or wireless. In general, the results look pretty good as far as I can tell. Were these tests run while saturating the connection as Fraser mentioned? I'll link the guide below again for convenience. http://support.netduma.com/en/support/solutions/articles/16000074717-how-to-test-your-internet-ping
morph1kx Posted July 15, 2022 Author Posted July 15, 2022 55 minutes ago, Netduma Liam said: In general, the results look pretty good as far as I can tell. Were these tests run while saturating the connection as Fraser mentioned? I'll link the guide below again for convenience. http://support.netduma.com/en/support/solutions/articles/16000074717-how-to-test-your-internet-ping Here tests when i saturated as much as possible
Administrators Netduma Fraser Posted July 15, 2022 Administrators Posted July 15, 2022 There will be a percentage that works best for you, you also don't have to have download & upload at the same percentage, they can differ. To clarify, you've tried every 1% between 5 & 100%?
morph1kx Posted July 15, 2022 Author Posted July 15, 2022 8 minutes ago, Netduma Fraser said: There will be a percentage that works best for you, you also don't have to have download & upload at the same percentage, they can differ. To clarify, you've tried every 1% between 5 & 100%? I need to try every value and combination? I tried various combinations including different upload and download.but no, not every possible value
morph1kx Posted July 15, 2022 Author Posted July 15, 2022 I just a little bit confussed.Why i dont get this ping spikes and packet loss with different router.Everything is stable even if this router without QoS?
Administrators Netduma Fraser Posted July 15, 2022 Administrators Posted July 15, 2022 You don't have to try every percentage specifically but identify a value at a 10% interval that seems to stabilize it the most, then try 5% either side, if there is still room for improvement try 4% either side and so on until you land on the best value. With another router without QoS but the connection is saturated you don't get any lag whatsoever?
morph1kx Posted July 15, 2022 Author Posted July 15, 2022 35 minutes ago, Netduma Fraser said: You don't have to try every percentage specifically but identify a value at a 10% interval that seems to stabilize it the most, then try 5% either side, if there is still room for improvement try 4% either side and so on until you land on the best value. With another router without QoS but the connection is saturated you don't get any lag whatsoever? I have tested 2 other routers and none of them have this problems.Even when saturated my gaming is smooth,sometimes my ping flactuate by 1-2 ms but only when playing wireless.I dont have that packet loss and ping spikes ever. By the way my first netduma R2 was smooth too(wired definetly).Its only started with my second unit of R2
Administrators Netduma Fraser Posted July 15, 2022 Administrators Posted July 15, 2022 That's very peculiar, given saturating your connection would mean there is literally no space for gaming traffic to be consistent, do you see the ping fluctuate on the Geo-Filter when it fluctuates in game?
morph1kx Posted July 15, 2022 Author Posted July 15, 2022 34 minutes ago, Netduma Fraser said: That's very peculiar, given saturating your connection would mean there is literally no space for gaming traffic to be consistent, do you see the ping fluctuate on the Geo-Filter when it fluctuates in game? I will check
morph1kx Posted October 14, 2022 Author Posted October 14, 2022 On 7/15/2022 at 6:44 PM, Netduma Fraser said: That's very peculiar, given saturating your connection would mean there is literally no space for gaming traffic to be consistent, do you see the ping fluctuate on the Geo-Filter when it fluctuates in game? I dont get ping spikes in geo filter. But my wifi speeds are dropping to 10mbps and lower.With wired i get occasional stutters and ping spikes
morph1kx Posted October 14, 2022 Author Posted October 14, 2022 I replied after long break from r2.Now tried again and still the same problem
Netduma Liam Posted October 14, 2022 Posted October 14, 2022 Maybe we're dealing with some Wireless contention here. Could you try downloading a Wi-Fi Analyser (there's one on the Microsoft store called Wi-Fi Analyser) and run a couple tests. Find which channels are least congested and switch your Wi-Fi on the R2 to use those. I know you mentioned you'd experimented with some different ones, but this test actually tells us which are the best to use. Now the R2 is back in the network, you've currently got ALL devices connected to it again, is that right? Have you still got the Traffic Prioritisation rule we added for your games console, and you're still seeing occasional stutters and ping spikes with this? Is this occuring when the network is very busy (downloads, updates, etc) or do you get this regardless of how busy the network is?
morph1kx Posted December 3, 2022 Author Posted December 3, 2022 On 10/14/2022 at 4:44 PM, Netduma Liam said: Maybe we're dealing with some Wireless contention here. Could you try downloading a Wi-Fi Analyser (there's one on the Microsoft store called Wi-Fi Analyser) and run a couple tests. Find which channels are least congested and switch your Wi-Fi on the R2 to use those. I know you mentioned you'd experimented with some different ones, but this test actually tells us which are the best to use. Now the R2 is back in the network, you've currently got ALL devices connected to it again, is that right? Have you still got the Traffic Prioritisation rule we added for your games console, and you're still seeing occasional stutters and ping spikes with this? Is this occuring when the network is very busy (downloads, updates, etc) or do you get this regardless of how busy the network is? Hello again.Sorry for the long wait, i was very frustrated with my problem and used another basic router. When i was informed about changes in dumaos, I Installed latest beta firmware + cloud update (for dpi changes). Now web surfing a lot smoother and most important - no ping spikes in games (at least online games are playable now) . I tried wired and wireless gaming. By the way i did factory reset after update ,but settings the same what i always use. I really hope this is not temporary changes and i can play games without problems. I will inform you if the problem reappear Netduma Fraser 1
Administrators Netduma Fraser Posted December 3, 2022 Administrators Posted December 3, 2022 Great to hear that, thanks for the update, keep us posted!
