Openvpn doesnt seem to work with netduma (Not using hybrid vpn)
thatguy11
I'm trying to use the OpenVPN GUI, and use my configurations from NoLagVpn to connect although it seems to not be connecting to any servers.
in game. Ive tried with and without geo filter. As well as removing my device from geo filter entirlery. I don't have my router in bridge mode. router is in Dmz, and plays normally without the vpn.
prior to the firmware update and cod update I had no issue connecting.
Does HybridVPN provide you with a log? Does it connect but it's not changing your IP etc?
I don't have it setup through hybrid vpn.
Im located on the west coast I am using The OpenVpnGui connecting to Singapore, or Hawaii. Whenever I use the hybrid function I receive no log, and only vpn the warzone ports, however it either crashes my game or stream or wont connect to any servers. Previously when I was using OpenVPNgui it worked fine.
If you're not using HybridVPN to set it up you may need to contact NoLag about it, it's also possible the game has banned the VPN servers
Okay what would would be the optimal setup for hybrid vpn.
I have previously used hybrid vpn; via only Vpning the ports. Should I keep my geo filter on filter mode around my actually location (only worked in Hawaii server so far).
If you're connecting to a server that's not in your location you should put your location on the server location, there isn't a Hawaii game server so that may be why you've struggled so far, ports are fine to use.
57 minutes ago, thatguy11 said:
So i.e I vpn to Singapore, I should put myself in Singapore in my geo filter?
Yes exactly!
I currently have it on always, with my pc being the only device connected.
51% download (slider)
98% upload (slider)
And dumaos calcified games turned on.
18 minutes ago, thatguy11 said:
it is prioritizing more but not as much as it used to.
How much are you expecting to see? How long have you had the rule enabled for approximately? Assuming it's been enabled since not long after Fraser suggested it, that looks like it's prioritised quite a lot of traffic.
Im expecting to see, similar numbers to the twitch packets. at least in the millionth decimal place.
and my download is is being prioritized a quite bit less than normal.
had it on for about 2 days.
It would not be similar to Twitch, live streaming is a heavy bandwidth service, gaming barely uses any bandwidth at all so they wouldn't be that similar.
How is the PC connected, via ethernet or WiFi?
53 minutes ago, thatguy11 said:
Yeah i used to get millions of packets now its barley 200,000
ethernet.
Just out of interest, if you reset Bandwidth Allocation, do the packets increase more rapidly?
On 1/19/2022 at 9:07 AM, Netduma Fraser said:
Add the PC with the Games Console service and then it should prioritize more
Believe it or not idk if its just me but when i manually prioritize cod instead of the games console it feels a little better. Idk if its just me but idk if the games console picks up COD. Again thats just me. I could be wrong but since i manually prioritized cod and applied it to wan it feels better.
Some people have commented on that so there may be something to it, we've got a new version not to far away which does have some backend QoS improvements so would be interesting to see the overall experience on this.
Ill give this a try and report back.
