Best setting for bullet reg call of duty vanguard
10 minutes ago, Netduma Fraser said:
Where did you set the MTU exactly? Did you ensure you chose a value that doesn't cause fragmentation?
In the Wan setting on my XR. In order for me to test if there is fragmentation I need to change the MTU value and when i change it, I get no internet access
I have watched xpromvz's stream and every game for 5 hours he has flawless bullet reg, how is this possible?he told me he used 1gig Fios internet. I have had such inconsistency with the netduma so far.
Does your connection require PPPoE? A moderator recently reported it causing a lot of problems with hit registration.
Yes it does, how can I fix this?
If you can have another router handle PPPoE instead that could help
I have an Asus rtac5300 that could run PPPoE. How would I setup the XR thou? Would it have a Dhcp conflict?
There wouldn't be a conflict, you can copy the WAN IP from the System Information page on the XR once it's connected to the Asus and then put it in the Asus DMZ, that will allow you to have an Open NAT, then see if it performs better.
IL give it a try, thanks
Can anyone else share their experience using this method?
Did you try it, what did you find?
I just set everything up, I will test it out later today.
I just played my first game and the difference is night and day, bullet reg is almost instant. Let's see if it continues this way in different lobbies.
Two games later, it the worst connection I have had in the last month. I have played 5 more games and it's terrible
If it changes that extremely then I doubt there is an issue on your side at all
It's like the more I play the worst the reg gets. It feels like the router gets filled up
If that's what it feels like give the router a reboot, does it play better after that?
