Low speeds on connection benchmark
I thought I saw someone else on here at one time talking about this but I'm getting like half my speeds when I do a connection benchmark test. I have 1000 up and 1000 down...but for some reason its only giving my 540 up and 430 down which results in a D. I have Qos disabled and I have the congestion set to never to make sure nothing is interfering with it. I'm not running any games and I have my console off. Any reason as to why my XR500 is only giving me half speeds?
Are you seeing the same speeds if you do a third party speed-test, using speedtest.net for example? If not, it's likely an issue with Connection Benchmark's reporting and won't actually affect your bandwidth. We're working on improving this for future firmware.
not its just with your benchmark....att speedtest and speedtest.net all worked somewhat fine.
As above we're still working on improving the results reported by Benchmark, if you're getting full speeds on other sites then those are the speeds you're getting so nothing to worry about.
  • 4 weeks later...
I'd like to schedule regular tests on my router, so thought I'd give another example of the discrepancy.  The DUMAOS test is consistent in its reporting, just incorrect on speed.
Yeah we are still improving the results shown by benchmark so you can ignore the speed there.
