Heroxoot Posted October 10, 2021 Share Posted October 10, 2021 I'm having major connection issues with my XR450 (FW 2.3.2.114) when using my Xbox Series S. It will fail to download games, load the store, pause/cancel installations. I cannot for the life of me figure out the issue or perhaps setting in the router causing it. I have connected the xbox directly to the ethernet from my fiber provider and it functioned completely normal, so I am 100% certain it's the router. What can I do? I've so far tried disabling QOS and DMZing the xbox. I've tried setting static IP/DNS in the xbox. It will work for a little while and then just become messed up and slow again. I couldn't even download a 1gb game until I directly connected it, and this console requires it to CONSTANTLY check for authorization of my gamepass. It's really frustrating how much issue a gaming router has with GAMING. I've had a lot of problems with this router since day 1. Constant wifi problems, weird connection issues with wired devices. My Samsung phone some days can't load a damn thing till I drop it off the wifi and connect back. I'm about ready to get rid of it for a regular Duma R2. Netgear doesn't seem to give a damn about anything besides the XR1000 now. I'm about to try the .120 firmware as I found it while making this post. But everything has been just awful lately. I've made threads in the past and I've gotten some help from mods here and I appreciate a lot of it. I just don't know what the issue is. If it's hardware or software related. Link to comment Share on other sites More sharing options...
Newfoundland Posted October 10, 2021 Share Posted October 10, 2021 Give .120 a go but perform a factory reset after updating using the rear pin hole. Set up as new and see how it goes. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted October 10, 2021 Administrators Share Posted October 10, 2021 Good advice above! When you do a speed test on the console, what results do you get for speed and NAT? Have you done any other changes on the router, port forwarding etc? Link to comment Share on other sites More sharing options...
Heroxoot Posted October 10, 2021 Author Share Posted October 10, 2021 10 hours ago, Newfie said: Give .120 a go but perform a factory reset after updating using the rear pin hole. Set up as new and see how it goes. I gave it a shot and my XBOX is doing great but now Discord has lag issues and so does Twitch. Voices constantly cutting out on discord and stream buffers. Link to comment Share on other sites More sharing options...
Heroxoot Posted October 10, 2021 Author Share Posted October 10, 2021 Geofilter also isn't working at all. It used to show steam server, discord server, and the logitech update server. Now it shows nothing. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted October 10, 2021 Administrators Share Posted October 10, 2021 Now you'll need to setup QoS to prevent lag and you should be good. For Geo-Filter: Quit the application/game/client completely Remove device from the Geo-Filter Give PC PlayStation Device Type in the Device Manager Resync from the Geo-Filter Map menu Re-add the device to the Geo-Filter with the manual option Set up the Geo-Filter how you like Wait 2 minutes Boot up application/game/client Link to comment Share on other sites More sharing options...
Heroxoot Posted October 11, 2021 Author Share Posted October 11, 2021 10 hours ago, Netduma Fraser said: Now you'll need to setup QoS to prevent lag and you should be good. For Geo-Filter: Quit the application/game/client completely Remove device from the Geo-Filter Give PC PlayStation Device Type in the Device Manager Resync from the Geo-Filter Map menu Re-add the device to the Geo-Filter with the manual option Set up the Geo-Filter how you like Wait 2 minutes Boot up application/game/client rebooting my PC seemed to be the answer but I did set up QOS to give priority to VOIP, live stream, and Gaming. Link to comment Share on other sites More sharing options...
Netduma Liam Posted October 11, 2021 Share Posted October 11, 2021 6 hours ago, Heroxoot said: rebooting my PC seemed to be the answer but I did set up QOS to give priority to VOIP, live stream, and Gaming. OK thanks for letting us know, are you still experiencing lag with Discord and Twitch? Link to comment Share on other sites More sharing options...
Heroxoot Posted October 11, 2021 Author Share Posted October 11, 2021 5 hours ago, Netduma Liam said: OK thanks for letting us know, are you still experiencing lag with Discord and Twitch? Uh, no actually. Wifi performance even with a range booster has been a bit wonky, but I think it's just thick walls now. Before I could be standing next to it and have issues. So, yea, this FW is great so far. Hopefully people with problems just have a botched setting somewhere or just a bad flash. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted October 12, 2021 Administrators Share Posted October 12, 2021 Great to hear that, thanks for the update! As it's resolved I'll close the topic, feel free to open another if needed and we'll be happy to help. Link to comment Share on other sites More sharing options...
