Exodia Posted August 2, 2021 Share Posted August 2, 2021 Hi Netduma guys, I am currently having issues streaming some services like HBO Max and Disney+. I want to configure the traffic prioritization for these two services but they are not in the list, I wanted to know how I could configure these services in traffic prioritization selector advance. If you can help me with this it would be great, Thanks, Exodia Link to comment Share on other sites More sharing options...
Netduma Liam Posted August 2, 2021 Share Posted August 2, 2021 Welcome to the forum Exodia! What device are you watching these services on? If it's on a Smart TV you can just prioritise all ports from that PC, if it's on a PC it's a little harder as the service will just use the HTTPS port of 443. Link to comment Share on other sites More sharing options...
Exodia Posted August 4, 2021 Author Share Posted August 4, 2021 On 8/2/2021 at 5:06 AM, Netduma Liam said: Welcome to the forum Exodia! What device are you watching these services on? If it's on a Smart TV you can just prioritise all ports from that PC, if it's on a PC it's a little harder as the service will just use the HTTPS port of 443. Thanks for your reply. Actually I'm using a smart TV, exactly a TCL C715. How can I identify wich are the ports than I need to prioritize? Link to comment Share on other sites More sharing options...
Netduma Liam Posted August 4, 2021 Share Posted August 4, 2021 8 hours ago, Exodia said: Thanks for your reply. Actually I'm using a smart TV, exactly a TCL C715. How can I identify wich are the ports than I need to prioritize? Go ahead and add a rule to Traffic Prioritisation and select the TV as the device. Then in the advanced configuration set the ports for both source and destination to 1-65535. You should then see that all traffic from the TV is prioritised when detected. Link to comment Share on other sites More sharing options...
