Ben Tester Posted March 31, 2021 Posted March 31, 2021 Was excited to unbox my new Netduma R2 today, I followed all of the instructions to set it up and I am not getting an internet connection from either WiFi or Ethernet. The wifi password worked and it shows full bars on my phone but everything I try to do online tells me i'm not connected to the internet. My pc can only use ethernet and it gets the same result. The strange thing is if I connect the little separate router I had before to the R2, with the R2 connected to my router/modem (provided by my ISP), I get a connection from the router connected to the R2. I am very confused and I really want to use this what looks to be an amazing product. plz help :(
Densha-Warrior Posted March 31, 2021 Posted March 31, 2021 hi! With your "little separate router", the connection was established automatically before or not?
Netduma Liam Posted March 31, 2021 Posted March 31, 2021 7 hours ago, Ben Tester said: Was excited to unbox my new Netduma R2 today, I followed all of the instructions to set it up and I am not getting an internet connection from either WiFi or Ethernet. The wifi password worked and it shows full bars on my phone but everything I try to do online tells me i'm not connected to the internet. My pc can only use ethernet and it gets the same result. The strange thing is if I connect the little separate router I had before to the R2, with the R2 connected to my router/modem (provided by my ISP), I get a connection from the router connected to the R2. I am very confused and I really want to use this what looks to be an amazing product. plz help Welcome to the forum! Have you been through the setup wizard yet? You'll likely need to do this before you get an internet connection. To do this, connect to your R2 and go to 192.168.77.1 in your web browser.
Ben Tester Posted March 31, 2021 Author Posted March 31, 2021 It is the next day and now i'm not even getting a wifi signal from my R2. I tried going to 192.168.77.1 and it says it could not be reached. I also tried holding the reset button for 30 seconds and then tried it again, still nothing. Also the 2.4 ghz and 5.0 ghz leds are now off. I can't find anything that can fix my problem.
Administrators Netduma Fraser Posted March 31, 2021 Administrators Posted March 31, 2021 Connect to the router via an ethernet capable device if possible then open command prompt on the PC and type ipconfig and press enter, then post the results here please.
Ben Tester Posted April 1, 2021 Author Posted April 1, 2021 Never mind it just randomly started working. Tip for anyone else with problem just wait and then it will eventually work.
Netduma Liam Posted April 1, 2021 Posted April 1, 2021 10 hours ago, Ben Tester said: Never mind it just randomly started working. Tip for anyone else with problem just wait and then it will eventually work. That's interesting, but we're glad to hear it! Just let us know if you have any further issues.
Ben Tester Posted April 27, 2021 Author Posted April 27, 2021 Hi again, I unplugged my R2 yesterday and I'm not getting any internet connection through it again.
Netduma Liam Posted April 27, 2021 Posted April 27, 2021 As in unplugged the power? What was the reason for this, were you experiencing any issues? Are you able to access the interface in your browser?
