scoobypreza Posted January 26, 2021 Posted January 26, 2021 So I've given up using the r2 for now the super weak wifi and the poor gaming performance on cod when using the r2 I'm behind what is happening in game and it's super frustrating to play went back to my tp link and used qos on that and boom connection is really good it's a night and day difference will try again when we get a firmware update but not holding my breath
Administrators Netduma Fraser Posted January 26, 2021 Administrators Posted January 26, 2021 Are you gaming through WiFi or ethernet? If you provide some screenshots of your settings and explain your physical setup we can make some suggestions. As you know we're working on WiFi improvements.
scoobypreza Posted January 26, 2021 Author Posted January 26, 2021 Not using wifi for gaming all the test I do come back with good results 8ms ping on the test bench mark with the r2 there is a delay like I'm 500ms behind with the top link it's fine
Administrators Netduma Fraser Posted January 26, 2021 Administrators Posted January 26, 2021 If you're modem/router is setup correctly and passes all the traffic straight through to the R2 then there shouldn't be a problem in that regard with QoS prioritizing the game above all else.
scoobypreza Posted January 26, 2021 Author Posted January 26, 2021 Yeah all set up r2 is set in DMZ still a massive delay
Administrators Netduma Fraser Posted January 26, 2021 Administrators Posted January 26, 2021 Could you provide a video of the kind of delay you're seeing if possible please?
scoobypreza Posted January 26, 2021 Author Posted January 26, 2021 It's not really something I can film it's not something you could see it's the way I die insta death and every 3rd or 4th bullet I shoot dont register a hit with r2 and gun fights seem fair when using the tp link. Here is a clip of me shooting at a chopper with bullets not getting hit Markers 20210109_203654.mp4
Administrators Netduma Fraser Posted January 27, 2021 Administrators Posted January 27, 2021 That does appear strange, I wonder if any other people have seen that at all. What is the ping shown in the game menu?
scoobypreza Posted January 27, 2021 Author Posted January 27, 2021 R2 shows 8ms in game 24 to 30ms this only happens when using the r2
Netduma Liam Posted January 27, 2021 Posted January 27, 2021 9 hours ago, scoobypreza said: R2 shows 8ms in game 24 to 30ms this only happens when using the r2 That's a pretty good ping to be fair, although it's interesting that there's such disparity between what the R2 records and what you see in game. Could you try manually blocking that server and see what results you get if you search again?
scoobypreza Posted January 27, 2021 Author Posted January 27, 2021 I have tried lots of different locations with different ping values and qos settings and get the same results when using the r2 12 minutes ago, Netduma Liam said: That's a pretty good ping to be fair, although it's interesting that there's such disparity between what the R2 records and what you see in game. Could you try manually blocking that server and see what results you get if you search again?
Netduma Liam Posted January 27, 2021 Posted January 27, 2021 Just to clarify, you said earlier you get 8ms ping in connection benchmark, if you go to Geo-filter while in game and click on the server you're currently connected to, does it also show 8ms ping there?
scoobypreza Posted January 27, 2021 Author Posted January 27, 2021 Yes 8ms when connecting to my local server which is london 2 hours ago, Netduma Liam said: That's a pretty good ping to be fair, although it's interesting that there's such disparity between what the R2 records and what you see in game. Could you try manually blocking that server and see what results you get if you search again?
Netduma Liam Posted January 27, 2021 Posted January 27, 2021 8 minutes ago, scoobypreza said: Yes 8ms when connecting to my local server which is london OK, that sounds good. Could you provide a screenshot of your QoS config?
scoobypreza Posted January 27, 2021 Author Posted January 27, 2021 I have tried every qos setting possible factory reset and reinstall firmware several times everything is set up as it should be every test I run on the r2 gives good results ping plotter DSL reports fast.com ect but like you can see in video shots dont register I die instantly even in warzone what I see at my end is not what the game server sees but if plug straight into my tp link all the issues disappear with the same qos setting that are on the r2
Administrators Netduma Fraser Posted January 27, 2021 Administrators Posted January 27, 2021 Are any devices still connected to your ISP router?
Administrators Netduma Fraser Posted January 27, 2021 Administrators Posted January 27, 2021 Do you have UPnP, port forwarding or the firewall enabled on the ISP router?
scoobypreza Posted January 27, 2021 Author Posted January 27, 2021 Upnp is off and r2 ip put into dmz on to link
Administrators Netduma Fraser Posted January 27, 2021 Administrators Posted January 27, 2021 Does it have a firewall enabled as that can interfere with the traffic.
Administrators Netduma Fraser Posted January 27, 2021 Administrators Posted January 27, 2021 If any devices connect to it by accident, say for example if WiFi is still broadcasting then they may be subject to the firewall rules, better to disable basically everything on it.
scoobypreza Posted January 27, 2021 Author Posted January 27, 2021 2 minutes ago, Netduma Fraser said: If any devices connect to it by accident, say for example if WiFi is still broadcasting then they may be subject to the firewall rules, better to disable basically everything on it. Wifi is off on tp link and r2 only thing plugged in so firewall is not the issue
Administrators Netduma Fraser Posted January 27, 2021 Administrators Posted January 27, 2021 Could you provide a similar video direct to the TP please so we can compare it?
scoobypreza Posted January 27, 2021 Author Posted January 27, 2021 Here you go ps5 plugged in to the tp link every shot registers 20210127_215844.mp4
