traffic prioritization help
DAKOTADOCKALL
I used wireshark on my PS5 to find out what i need to use for my traffic prioritization.
Im wondering if i set this up right if anyone can help me it would be much appreciated.
Also this are from cold war.
Edit the second one is going up on download and upload without the red circle being on
For anyone experimenting with ports its more what feels good to you. I think you've added too many ports personally as the game only uses these:
  • TCP: 1935,3478-3480
  • UDP: 3074,3478-3479
Someone just posted what works for them so mabye give that a try.
On 1/4/2021 at 5:29 PM, Netduma Fraser said:
Yeah give that a go and see, its a bit more specific than yours so may work better.
Hey, on my R2 im getting super high upload packet priority.
Any reason why please?
You're prioritizing a lot of ports on the destination side that wouldn't be used in game so would recommend fine tuning that to make it more specific.
How would i go about doing this?
Have a look at this:
Alright im back i test the ports i got from wireshark yesterday for about 6 hours. And i just got done testing the ones from the other post and the wireshark on was way better feeling hit reg days and nights better ill just have to find the right ports out of the large number of the wireshark ports.
Guest
