Mubarak Posted October 26, 2020 Author Posted October 26, 2020 Does my phone need to be connected to the R2 all day ? Or it doesn’t matter ?
Administrators Netduma Fraser Posted October 26, 2020 Administrators Posted October 26, 2020 Okay great thanks, no that doesn't need to be connected. As long as the R2 is connected to the main network, has internet access and is accessible then that is all that is needed.
Administrators Netduma Fraser Posted October 26, 2020 Administrators Posted October 26, 2020 Couldn't access you, I tried to ping you and I couldn't do that, have you got an option enabled somewhere to block pings?
Mubarak Posted October 26, 2020 Author Posted October 26, 2020 ( Allow ping ) on my R2 is enabled already...
Administrators Netduma Fraser Posted October 28, 2020 Administrators Posted October 28, 2020 Could you email [email protected] with a link to this topic and your order number please. Let them know I recommend to get you a replacement as we have tried many times to access you but have been unable to and to collect your router so we can take a look in house.
Stobbee Posted January 5, 2021 Posted January 5, 2021 Did you find any solution for this problem? I'm facing the same issue, stack at 100mbit no matter what cable I use.
Administrators Netduma Fraser Posted January 5, 2021 Administrators Posted January 5, 2021 3 hours ago, Stobbart said: Did you find any solution for this problem? I'm facing the same issue, stack at 100mbit no matter what cable I use. What does the link speeds say for all the ports in the Device Manager table view?
pheroux Posted September 22, 2021 Posted September 22, 2021 I have the same problem with my Netduma R2...
Netduma Liam Posted September 22, 2021 Posted September 22, 2021 10 hours ago, pheroux said: I have the same problem with my Netduma R2... Could you please create a new topic for your issue so we can help you there.
KeReFiS Posted October 16, 2022 Posted October 16, 2022 It seem like I'm facing this issue also I want to jump to solutions!
Administrators Netduma Fraser Posted October 16, 2022 Administrators Posted October 16, 2022 19 minutes ago, KeReFiS said: It seem like I'm facing this issue also I want to jump to solutions! Could you make a new topic please and we can help you there
bhuttehai Posted October 17, 2022 Posted October 17, 2022 what is the way to solve this issue ! Please this is affecting my work also ! hellodear.in teatv download
Administrators Netduma Fraser Posted October 17, 2022 Administrators Posted October 17, 2022 2 minutes ago, bhuttehai said: what is the way to solve this issue ! Please this is affecting my work also ! Hey, welcome to the forum! In most cases it will be the ethernet cables you're using that are limiting you so make sure you're using Cat5e cables or higher.
