crunkjuice1 Posted September 27, 2020 Posted September 27, 2020 I had never experienced this with .56 stable firmware within LAN detection of Arlo Pro 2 security camera base station registering as a gigabit connection. Now with the 3.0 beta firmware the base station is working fine but it is being detected as a non gigabit connection. Light is orange instead of white. I have factory reset router as a standard after firmware update process. The base station is also one of the many devices that bounce between online and offline modes in device management.
Administrators Netduma Fraser Posted September 27, 2020 Administrators Posted September 27, 2020 Is it using the exact same ethernet cable as before? Do you have another ethernet cable you can switch it out for to test with?
crunkjuice1 Posted September 27, 2020 Author Posted September 27, 2020 Yes it’s the same. I will switch it out for this testing purpose and report back give me a few minutes.
crunkjuice1 Posted September 27, 2020 Author Posted September 27, 2020 Ok swapped cables and ports on XR500 and still the same. Port 4 is Arlo base station port 1 is my Xbox. I added the arp error pic as a side quest in the list of what you guys have on hand.
crunkjuice1 Posted September 27, 2020 Author Posted September 27, 2020 You guys have an email I can add within the XR500 that I can send in the logs?
Administrators Netduma Fraser Posted September 27, 2020 Administrators Posted September 27, 2020 If you downgrade back to .56 does it work correctly? If so then post the issue on the Netgear beta forum please and you can download the log straight from System Information and attach it there.
Newfoundland Posted September 27, 2020 Posted September 27, 2020 If this helps, I have the Arlo pro 2 and it’s a 100mb connection to the router I’m using. It does not require a gig connection rate.
crunkjuice1 Posted September 27, 2020 Author Posted September 27, 2020 34 minutes ago, Newfie said: If this helps, I have the Arlo pro 2 and it’s a 100mb connection to the router I’m using. It does not require a gig connection rate. This was what I was going to look into but since I had it for so long running on .56 firmware and the LAN light was always white this made me wonder both sides of the coin. Was it not working right on 56 and nobody ever caught that little hiccup. I will still post this over on the netgear board and see what netgear has to say for confirmation. I am 99.9999999% you are correct Newfie 🤟🏽
