Wintercabin Posted May 13, 2021 Posted May 13, 2021 4 minutes ago, Netduma Fraser said: Nope, just filter as you normally would and you should be able to force the closest servers now - it should work for PC as well yes If you're not on the 3.0 beta then just add it to the Geo-Filter and then setup how you want to filter and it should work Thanks! - What settings would you recommend for optimal performance? Here is what is my settings look like. When should I 'flush cloud'?
Administrators Netduma Fraser Posted May 13, 2021 Administrators Posted May 13, 2021 55 minutes ago, wintercabin said: Thanks! - What settings would you recommend for optimal performance? Here is what is my settings look like. When should I 'flush cloud'? I'd recommend using Strict Mode so you only get servers within your radius, everything else is personal preference really but wouldn't suggest using fast search. The update should have automatically been downloaded to your router by now so no need to flush it but if you ever get the sense servers aren't appearing as they should be then flushing the cloud can resolve that.
Administrators Netduma Fraser Posted May 15, 2021 Administrators Posted May 15, 2021 2 minutes ago, Reithreges said: Anyone tested this update yet? You should be able to filter servers now, give it a try and see how you get on!
Reithreges Posted May 15, 2021 Posted May 15, 2021 I've just tested it and the filters don't really seem to be working, regardless if filtering node is on or off the results seem the same, unless I'm doing something wrong
Administrators Netduma Fraser Posted May 15, 2021 Administrators Posted May 15, 2021 34 minutes ago, Reithreges said: I've just tested it and the filters don't really seem to be working, regardless if filtering node is on or off the results seem the same, unless I'm doing something wrong Are you covering areas where you know there are servers? Are you getting kicked just before you load into the game? If so do you notice anything blocked on the map? (make sure to be fully zoomed out)
Administrators Netduma Fraser Posted May 15, 2021 Administrators Posted May 15, 2021 42 minutes ago, Reithreges said: So I need to have my cyrcle on a server square? Yes you need to cover servers with your radius/polygon in order to force them and filter by server
