Jitter in speed test
Wondering what settings would control jitter in Speedtest. I have been noticing some pretty high jitter sometimes as high as 20ms when I usually had very little around 1.5ms
In my experience, turning Anti-Bufferbloat to around 70% can reduce jitter by setting a cap on the low side of the fluctuation.
How are you performing your speed test, are you wired or wifi? Also what site/software are you using? The best method to test jitter is to run pingplotter. A screenshot would also help diagnosis.
I was at 70% anti buffet bloat. I have yet to get PingPlotter to work very well on my phone, but iPhone X couple feet away from router on Speedtest.net app I would see on the main servers from me almost no jitter. I lowered anti buffer bloat and things stayed the same. I will try and move my desktop to get wired connection.
Very strange. Do you think it could be due to other devices on your network using data in little bursts?
Disable IPv6 and try again please. Also try when directly connected to the modem itself and see if you get the same issues. It's important to try wired on modem and router, if there is no issue there then its probably WiFi congestion/contention
