EfootballPlayer Posted July 30, 2019 Posted July 30, 2019 Good guys, I have a speed of 100 mb per fiber and the problem is with the quos, and when I change 70 or any other speed, the download speed works well if the quos works well but for the upload it is still not optimized since keep giving 100. I've tried to update firmware, reset and even change the firmware to an older one, active and desactive the good put, but it's still the same I don't know what to do, see if you can help me, thanks.
AI_EXREYFOX Posted July 30, 2019 Posted July 30, 2019 Hello you use vlan tagging for internet if so ... is a old bug
EfootballPlayer Posted July 30, 2019 Author Posted July 30, 2019 Yes i use if desactive the Internet dont work, how solve?
AI_EXREYFOX Posted July 30, 2019 Posted July 30, 2019 You have to wait like me for an firmware fix update
Administrators Netduma Fraser Posted July 30, 2019 Administrators Posted July 30, 2019 As above, sounds like VLAN which is something we are looking into. I've passed this on to the team as well.
Administrators Netduma Fraser Posted July 30, 2019 Administrators Posted July 30, 2019 1 minute ago, jordi08110 said: Mmm, how solve any idea? The developers need to create a fix, they're already aware of it so nothing can be done from your side at the moment.
EfootballPlayer Posted July 30, 2019 Author Posted July 30, 2019 Uff, and this will be linked in anticipation of an imaginary update that the last one was 6 months ago can it be?
Administrators Netduma Fraser Posted July 30, 2019 Administrators Posted July 30, 2019 Last was at the end of April which was a hotfix firmware for an issue. I can't give a deadline on when that might be resolved unfortunately but I've added your post to the list of people who need it so it gives more weight to prioritizing it.
EfootballPlayer Posted July 30, 2019 Author Posted July 30, 2019 This hotfix solve the problem from september o more?
Administrators Netduma Fraser Posted July 30, 2019 Administrators Posted July 30, 2019 No I'm just saying there has been a firmware update sooner than you thought. No, the team will need to work on a fix.
EfootballPlayer Posted July 30, 2019 Author Posted July 30, 2019 This update only solve problems of restarts of some users, only this and me no affect this hotfix but i put for test and have the same problem...
AI_EXREYFOX Posted July 30, 2019 Posted July 30, 2019 O can bypass this bug, in my past setup i was use a managed switch like tp-link sg-105E SETUP: ONT- 105e-XR500, the 105E control my vlan tagºs and vlan untagºs you need a vlan untag for xr500 to work
Administrators Netduma Fraser Posted July 30, 2019 Administrators Posted July 30, 2019 I was just making you aware of a more recent firmware, I know it's not for your VLAN issue, we'll work on that. As i mentioned in the other topic and what Dave has suggested here is a good alternative meanwhile.
EfootballPlayer Posted July 31, 2019 Author Posted July 31, 2019 The router xr700 have the same problem or is the same of xr500, i contact by phone with the technical support of netgear and offer me a substitución of My xr500, if the xr700 not have this problem i change with this payment the difference. Thanks
Administrators Netduma Fraser Posted July 31, 2019 Administrators Posted July 31, 2019 I believe it will have the same issue so it is unlikely to make a difference if you switch to the XR700 unfortunately. The best advice at the moment is using another router for VLAN then the XR router can control all devices perfectly.
AI_EXREYFOX Posted July 31, 2019 Posted July 31, 2019 You can buy a cheap router with no wireless edgrouter-x I have one and its a great router, have a SQM and you can config vlans
Bert Posted July 31, 2019 Posted July 31, 2019 23 hours ago, WalkedDave said: O can bypass this bug, in my past setup i was use a managed switch like tp-link sg-105E SETUP: ONT- 105e-XR500, the 105E control my vlan tagºs and vlan untagºs you need a vlan untag for xr500 to work Interesting, how did you set that up? I have a S8000 switch between my XR500 and ONT. Whenever I set it to tag traffic from the port where the XR500 is connected to, doesn't work. When I set VLAN per port it does work a bit but I won't get a internet connection in game.
EfootballPlayer Posted July 31, 2019 Author Posted July 31, 2019 La idea de otro enrutador u ont / enrutador es más trabajo para xr500 y la conexión sucia piensa, porque si continúe con solo ont, el problema de vlan solo afectará cargar antibufferbloat o afectará otras optimizaciones de xr500. Because how is the Best configuration of My router/ont for dont have control of traffic and work better the xr500?
Administrators Netduma Fraser Posted July 31, 2019 Administrators Posted July 31, 2019 7 minutes ago, jordi08110 said: The idea of other router or ont/router is more work for xr500 and dirty the connection think, because if continúe with only ont, the problem of vlan is only affect to upload antibufferbloat or affect other optmizations of xr500? No it won't affect the connection/effectiveness of the XR500 at all. It is perfectly normal to have a setup like that.
EfootballPlayer Posted July 31, 2019 Author Posted July 31, 2019 But only affect to upload antibuffer or dont work other options? How solve the problem of nat moderate in Ps4, i test with put ip in DMZ xr500 and dont work, and upnp Nothing, add manually ports to ps4 ip Nothing,ever reset when test These options, any solution Thanks
Administrators Netduma Fraser Posted July 31, 2019 Administrators Posted July 31, 2019 If you have the VLAN settings on the XR500 it will just affect upload. If you do modem > router handling VLAN > XR500 then all XR500 features will work. Are you referring to NAT Type 2? If so that is open, just means you are behind a router which is normal.
EfootballPlayer Posted July 31, 2019 Author Posted July 31, 2019 5 minutes ago, Netduma Fraser said: Si tiene la configuración de VLAN en el XR500, solo afectará la carga. Si hace módem> enrutador que maneja VLAN> XR500, entonces todas las características de XR500 funcionarán. ¿Te refieres a NAT Tipo 2? Si es así, está abierto, solo significa que está detrás de un enrutador que es normal. Have this, not is normal because before when work by xr500 witjh vlan tag dont have this problem with nat;
Administrators Netduma Fraser Posted July 31, 2019 Administrators Posted July 31, 2019 Okay so you're talking about the game NAT then, not the PS4 NAT. Disable the Geo-Filter then boot up the console, the Geo-Filter is likely causing a misreading.
AI_EXREYFOX Posted July 31, 2019 Posted July 31, 2019 2 hours ago, Bert said: Interesting, how did you set that up? I have a S8000 switch between my XR500 and ONT. Whenever I set it to tag traffic from the port where the XR500 is connected to, doesn't work. When I set VLAN per port it does work a bit but I won't get a internet connection in game. I dont know how s8000 works but tomorow i will post my old config.
