High Priority Traffic Detected issue and devices offline but showing online issue
Hi
Not sure if this is really an issue or there is a bug in the firmware.
But is High Priority Traffic always supposed to be on?
Even when its not selected as always.
None of the devices are on that use the setting, so I'm not sure why its on?
Is it because of the DCHP release on the firmware not working properly?
As I still have that issue, where devices show on line that are off line and vise verse.
Unable to delete them unless I reboot the router (which is getting annoying).
Is there any way to fix this yet?
In theory it should only be on when actual high priority traffic is detected, but it might be that something is triggering a false positive here.
Even when set to Always, the high priority traffic indicator should be accurate.
Have you added any manual rules to the Traffic Prioritization menu? Could you screenshot that section as well?
Thanks!
No manual rules added to it, its in default.
Are the packets updating as well? It might be detecting packets from a console if it's in a standby mode or from another device potentially. If you disable DumaOS Classified Games does it turn off?
Yes it turns off.
Does it pick up all consoles or just the one added to the geofilter, as thats what I thought it did.
I only have one device added to the geo.
No it's a separate feature, not tied with the Geo-Filter so it'll pick up all consoles, does that explain it then?
may be, I've turned it off and just sent it to my xbox and see how it goes.
Guest Killhippie
On 5/21/2019 at 5:35 PM, Ste G said:
Hi
I had this issue and it seemed to be caused by speedtests on port 80 by speedtest.net's app or other online speedtests on iOS devices (it may be others to but I use a iPhone Xs and iPad Pro 2018 model) Also if you do a speedtest while the router is switching back to "when High priority traffic is detected' that can cause the false positive in my testing, its like it gets stuck by the speedtest as it switches that mode off, not sure how long it takes to go back to not detecting high priority traffic but in that window a burst of traffic over port 80 can seem to cause it to get stuck.
deffo not speedtests.net  but thanks.
Which router and firmware version are you on?
