MrAllusive Posted April 4, 2019 Posted April 4, 2019 Hello! I've been dealing with this problem for some time. To access the Netduma, I cannot plug it into my Modem/router combo or I lose access to it. Unplugged, I can log in without any problems. This includes switching wifi networks and lan ports as well. Its as if the Netduma becomes invisible but still functions maybe as a switch for the console? I cannot make changes to the firmware without disconnecting from the main network. Has anyone else had these problems? Thanks.
bbursley Posted April 4, 2019 Posted April 4, 2019 Do you have the netduma in the DMZ or is it getting assigned a static IP? If you navigate to the IP that the modem/router combo is assigning it then you should be able to access it. Can you see that list of IPs for devices? or is that not possible?
progprogprog Posted April 4, 2019 Posted April 4, 2019 What ip address do you use to access the r1 gui page? 192.168.88.1 e.g Your modem/router default gateway ip address maybe conflicting with the r1
Administrators Netduma Fraser Posted April 4, 2019 Administrators Posted April 4, 2019 I would agree with the others above, sounds like it may be conflicting. Have you tried accessing via http://r1 ? If you're unsure of the IP then that should direct you to the interface
MrAllusive Posted April 4, 2019 Author Posted April 4, 2019 and just like that.. it started working!?! Thanks.. last time I used it was Jan 16th because I couldn't access it. Using http://r1 got it to work.. the Ip address didnt. Thanks
Administrators Netduma Fraser Posted April 4, 2019 Administrators Posted April 4, 2019 56 minutes ago, MrAllusive said: and just like that.. it started working!?! Thanks.. last time I used it was Jan 16th because I couldn't access it. Using http://r1 got it to work.. the Ip address didnt. Thanks Great to hear it. Double check the LAN IP in Settings > LAN and see if you can then access it using the IP
