Apex legends will not work with Geo Filter
sikpup
Any idea how to fix this?
When i click on Qos it gives this error and when i hit okay i see this loading icon which clearly means that my desired device isn't getting priorities. I've reset the router. Did power cycle also, but it didn't change.
  • Replies 90
A factory reset definitely should have fixed this. Did you have a device manually added to the feature that you've either deleted, renamed or done something with in Settings? If you reconnect that device/give it the old name then it should work again.
  • 6 months later...
Has there been a fix for this? I'm getting the code: Leaf error after a game or if I head into the Apex firing range. I just bought the XR500 and Apex doesn't have a profile in the Geo-Filter. I didn't have this issue with the C7800.
Sorry to hear you're having this issue. I would suggest using Spectating Mode for now and selecting the server on the game. I will chase Alex for an update on this.
  • 4 months later...
its been months and apex still does not work on netduma, this is the reason i got the R1 for apex low ping and its clearly not gonna work, ill be changing routers and i suggest you remove apex from the list of games, it does not work.
What firmware are you currently using? We are currently testing Apex as I type this so rest assured we haven't given up on it!
  • 1 year later...
Just wanted to keep this thread alive, as I and many others with DumoOS are still having issues with the Geo Filter on Apex. If theres anything you Devs need to help fix this issue please let me know. As far as use case scenario for me, apex works much better without the filtering. I can get it to work with it turned on, however it feels pointless as im still getting into high ping servers, granted thats more EA's fault than anything, but it continues to boot me after a match, and takes a few tries to get back into a search. Pubs matches seem to be better for the filter on my end, i dont have as much issue there but it will still boot me. Ranked matches on the other hand have much more trouble working, and when i do get into a match its like 60+ ping, which is decent but i have a server an hour away, or so it seems. I am almost never connected to the server close to me. Currently am on the latest R2 firmware 3.3, but thats not the issue, as this has been ongoing. I will say though, that the Geo Filter did used to work in the early Apex days back in 2019 on my XR500, so something changed thats causing this. Whatever the case, I am looking forward to the fix as Apex servers play on a very low refresh rate around 20hz so ping is crucial here. Godspeed
We believe filtering Apex should get better once we've released our new version of Geo-filter. The approach to filtering in this new version is completely changed and much less aggressive while still being very effective. This should mean that you don't get these strange errors thrown when servers are blocked. We don't yet have an ETA for this new version just yet, but we are currently testing it and making final improvements so it shouldn't be too much longer!
Thats exciting to hear! FINALLY, the ping we all deserve. When the realease happens is it going to be in a firmware update?
Yes it would be via a firmware update
Do you think its possible that there are authentication servers not only for connecting to a match but also when leaving a match back to the lobby in Apex? I noticed when I left a game (early mind you, i had died lol) that there was a server being responsive showing up as a peer server but was outside my filter being blocked. Currently i have the filter set to basicly half the us on the west side, i couldn't report the server to you guys as it gave me an error reporting it but im sure thats nothing to worry about. Just curious to that, as from what I've read on here theres no need to add authentication servers to the filter, but if the filter was mis-reading an authentication server, wouldn't that be the reason it boots us back to the main menu?
Interesting, I mean it's certainly possible, perhaps responsible for reporting your stats, yes that could cause it. If you come across that one again or other servers when kicked etc let us know the IDs and we can have a look into it.
Sure, I can do that. Post them here for you? or would you prefer some sort of document with a list of ones I can find
Posting here is absolutely fine, thank you!
  • 2 weeks later...
41cc27f269e0454a - Dedicated (pops up when connecting back to lobby after code leaf error)
4c92e6b12febfb00 - Peer Server europe
87ad39044a26e8ed - Possibly mislocated server
499286512fe8fb00 - Peer europe server
41ccc38e69e0454a - Dedicated (pops up when connecting back to lobby after code leaf error)
ee6b2ffa088d0106 - Domain Name apx-ams-041.multiplay.co.uk (server was popping up while playing and lagging in game was very bad)
05acb78249a4656a - Peer server (same spot as dedicated server)
41cc531e69e0454a - Dedicated (same as others)
0e94632e31ad4348 - Server outside of range popped up when game disconnect into code leaf error
these are some of the servers that i have noticed recently, I wouldve posted sooner but been busy with life an all lol, I'm keeping a list on my side as well to save ones i might find later. Let me know if theres more info you need
