Help Vlan in WaN PORT ?
I need help, to configure vlan on the wan port of my router.
The data from my internet service provider are
password: guest
Vlan: 100
 but only have potion of vlan in group or ports 1 2 3 4, I want to configure in the wan port, normal as before.
You either do it via bridge group and select everything or do it by tag group, edit the existing rule there to change it to 100
does not work ! When I make a vlan bridge on all ports, I can no longer access the router panel, I no longer have how to configure it. I want the router to connect to the internet through vlan 100, I do not want to use it as a bridge
Which router control panel does it bar you from? Is it DumaOS you're unable to access with those settings? Just to clarify as well, why precisely do you need to do this? Can you not achieve Internet access any other way?
I've found this guide on the topic though I'm not sure if what you're attempting to do is possible: https://www.manualslib.com/manual/1376128/Netgear-Xr500-Nighthawk.html?page=80 - might need someone else to pitch in on this!
  • 2 weeks later...
195/5000
I get an ONT from internet service.
to connect to DUMA OS and DUMA to make the ppoe connection with the VLAN 100 rule.
but I can not put the Vlan 100 rule on the wan port of DUMAOS XR500.
I need to include the vlan 100 rule for my wan connection. my provider gave me the following information for connection ppoe
PPOE Connection:
User: guest
Pass: guest
Vlan: 100
Faça os detalhes normais do PPPoE em Configurações> Configuração da Internet. Para VLAN, tente fazer isso:
At least one port MUST be chosen. When I select a port, the I can no longer access the router's panel.
I think you'll either need to set it up on individual devices as well or the best bet is to contact Netgear directly. Settings is their part of the software so they will be more knowledgeable regarding your issue http://support.netgear.com/
  • 1 year later...
