scbba Posted December 18, 2018 Posted December 18, 2018 Here are 2 test I ran with the r1 today and it seems my line is cleaner with just the modem its self. my settings on the R1 are I let it set its self up with 70/70 sliders and no matter what I do it doesn't change from what it looks like below my speeds are 100 down and 10 up but I rarely ever get that from them so I have it set at 60 down and 5 up which is closer to what i actually get.
Administrators Netduma Admin Posted December 19, 2018 Administrators Posted December 19, 2018 Was this test done over wired or wireless? And are you on DumaOS or are you on the original R1 firmware?
scbba Posted December 20, 2018 Author Posted December 20, 2018 wired connection with cat 7 and I am currently on the original fw for the r1 I wasnt getting dedis on the duma os so I downgraded
Netduma Staff Netduma Jack Posted December 20, 2018 Netduma Staff Posted December 20, 2018 4 hours ago, scbba said: wired connection with cat 7 and I am currently on the original fw for the r1 I wasnt getting dedis on the duma os so I downgraded What you might find scbba is that your Ethernet cable is the cause. I'm not trying to palm off the blame, I'm saying in my experience it's extremely rare for the router itself to be the cause of line quality issues like spikes / jitter. Ethernet cables are a far more likely cause, so try switching out your cables before your next test! As for not being able to connect to dedicated servers on DumaOS, that issue is long gone. We're still optimising the cloud but the Geo-Filter works great with DumaOS now
scbba Posted December 22, 2018 Author Posted December 22, 2018 OK I'll try a new cable and see what happens. I also went back Duma os 1.3 but now I can' get a open nat for anything and my bandwidh dropped from 4000 kb to 2800kb with the same settings
Administrators Netduma Admin Posted December 24, 2018 Administrators Posted December 24, 2018 These guides should help you with both of these things; Open NAT: http://support.netduma.com/support/solutions/articles/16000076587-dumaos-optimal-settings-guide-open-nat Max speeds: http://support.netduma.com/support/solutions/articles/16000076586-dumaos-optimal-settings-guide-maxmimum-bandwidth-speeds
scbba Posted December 30, 2018 Author Posted December 30, 2018 I have tried the manual and upnp and still can't get an open nat
Administrators Netduma Fraser Posted December 30, 2018 Administrators Posted December 30, 2018 Whats the model of your upstream modem?
