S13 Posted December 6, 2018 Posted December 6, 2018 Hi I am using Duma Os. I have download 70mbs , upload 20mbs. Its fluctuates when using net duma r1 duma os, upload drops to 400kbs or lower, and I get kicked from lobby. How to fix speed issues with Duma Os on R1 ?? Without netduma, I have no fluctuations. Full speed ... Please advise. Any recommended settings ? Or full setup ? Thanks
BIG__DOG Posted December 6, 2018 Posted December 6, 2018 Hi. I see you are in the UK. Who is your isp and how do you have your R1 connected to your modem or modem/router? Also how are you performing speedtests, wired or wireless?
Administrators Netduma Admin Posted December 6, 2018 Administrators Posted December 6, 2018 Worth also going through this guide just to make sure you have everything setup correctly: http://support.netduma.com/support/solutions/articles/16000076586-dumaos-optimal-settings-guide-speeds
S13 Posted December 6, 2018 Author Posted December 6, 2018 6 hours ago, BIG__DOG said: Hi. I see you are in the UK. Who is your isp and how do you have your R1 connected to your modem or modem/router? Also how are you performing speedtests, wired or wireless? 5 hours ago, Netduma Admin said: Worth also going through this guide just to make sure you have everything setup correctly: http://support.netduma.com/support/solutions/articles/16000076586-dumaos-optimal-settings-guide-speeds Hi My router setup modem etc etc is all fine as advised by Netduma techs. Please read below reason of Topic I created... Regardless of setup : speed fluctuations happen only while Netduma R1 router is running DUMA OS ! When its running Net duma firmware everything is fine. I actually had 1000 upload/1000 download somehow as bandwidth set. I adjusted it back to 70/20 . Hopefully it will fix ? Thanks for link to guide, I shall go through guide n settings tomorrow. But Cod bo4 is working perfect, 30ms lobbies, UK servers. And it takes about few seconds to find a match. Thanks again !
Administrators Netduma Fraser Posted December 6, 2018 Administrators Posted December 6, 2018 Okay keep us updated after those changes and going through the guide
S13 Posted December 7, 2018 Author Posted December 7, 2018 Made changes, plus plugged ethernet cable in different port on netduma r1. It seems to be fixed. Thanks
Administrators Netduma Admin Posted December 7, 2018 Administrators Posted December 7, 2018 That's great news. Thanks for letting us know.
