Upnp problem
witton90
Any body else having problem with upnp or port forward on Duma os, I have upnp enabled and it doesn't show up on table and it gives me moderate nat on bo4 xbox 1, I've reverted back to r1 firmware and have no problem at all with nat??
This is something that is known bug with the DumaOS. What I usually do, I would power down my console. Then I would head into the DumaOS settings and disable UPNP. I would then reboot the router. I would wait about a minute or two, and then once it's fully booted. I would head back into the settings and Enable UPNP. Then power on my console, and go to the playstation or xbox network settings and click "test internet connection". Then I would boot up said game i.e. COD, and check if it's open NAT. As you mentioned, original OS works, so this should work.
 - Tray
Nice one for the reply it says it's opened 3074 and 3075 in port table then in game shows moderate  and also bandwidth numbers aren't correct, thanks for reply tho will try this hopefully it works
cheers
jay.
Try out Tray's suggestion and let us know how you get on. You should be able to solve a moderate NAT using DumaOS anyway, shouldn't be any need to downgrade. Do you struggle to find a game / experience much worse gameplay on a moderate NAT? You should disable your Geo-Filter and see if you get an Open NAT.
No seems fine games play smooth, open at on network settings Xbox, just moderate in game, can connect with other players and shows port 3075 on table, didn't know wether it maybe blocking a server with geo
It's possible it's the Geo-Filter. But you can try port forwarding these ports if you're worried about it. In all honesty, if you are connecting to friends and games without problems I wouldn't sweat it too much:
Tonight it was open 😕 beginning to think might be the game, spawns seem slightly better since update, thanks for support tho :)
Thanks. I'll move this to the BO4 support subforum as it's better placed there.
