Ps4pro Geo filter not populating
I have used the R1 for years and finally picked up the XR500
I have setup my ps4pro under device manager to playstation
Added ps4 to geo filter as a console - Filtering mode (also tried spectating mode)
profile was set to destiny
I can't see any servers or triangles or anything on the geo filter map
Meanwhile...
I setup my pc and it works - I can see servers and triangles on the geo filter
PC is set to console (saw this in another thread)
geo filter is set to spectating
EDIT**
Just setup my Xbox1X and everything populates
xbox in device manager
set as console under geo filter in filtering mode
Can see servers and triangles
Hi, welcome to the forum!
It's possible your PS4 has been incorrectly identified by the XR500. If you go into the PS4 network settings and check the IP address, does it match the IP address shown on the XR500? By comparing the device in this way you can find out whether you have added the correct device to the Geo-Filter.
Also try deleting the device from the Geo-Filter and adding again. If you find that you have added the wrong device, make sure to find out which device is your PS4 by comparing the address and name it.
Yes, I always double check the addresses to make sure they match up.
I have removed the device multiple times from device manager and even set static address to it with no change.
Changed the name in the device manager to make sure I'm adding the correct device too.
Add the console to the Geo-Filter then click Flush Cloud in the Geo-Filter Map settings. Then try searching for a game. Also can you provide us with a screenshot of the entire Geo-Filter page please (Can upload to imgur and post the link here).
Did you change the device in Geo-Filter when you switched to WiFi? If not then you had the WiFi PS4 added the whole time not the wired PS4 added. If you did then this doesn't make any sense and would recommend switching ethernet cables.
Leave your ps4 in spectate mode, when you startup a game change over to filtered. Sometimes the servers will appear & disappear quickly before you can ping them.
Yes I deleted the wired geo filter device and setup the wifi device.  My consoles have never been on wifi.  First time was to test out this.
I've tried 3 different ethernet cables
tried removing the wired switch and connect directly to the router
It doesn’t really make any sense, the only thing I could possibly think of is NAT related. Does it have an open NAT?
ok I just went through and removed all network connections and soft reset my ps4
rebooted the xr500
deleted all the geo filters
logged out
setup everything again with just the ps4 on wired
and its working now.
I wonder if the xr500 was keeping old settings because I gave my ps4 a different static address
also with my ps4 off and disconnected from ethernet, I couldnt remove the device from device manager
I'll keep testing and re-add my pc and xbox to see what it does
Yea all NAT is open
PS4 is type 2
Okay great to hear that! It will wait a bit of time before you’re able to delete it usually in case it reconnects.
