ViciousSavag3 Posted April 14, 2018 Posted April 14, 2018 so i upgraded my internet to 1gigabit what would be the RIGHT SETUP for it in Miscellaneous? And also what Actual speeds do i have to put in the R1? The actual speed test or the speed that im suppose to be getting from my ISP which is the 1000mbps and 35 up?
BIG__DOG Posted April 14, 2018 Posted April 14, 2018 The R1 will support a maximum of 800mbps if superturbo mode is enabled.
ViciousSavag3 Posted April 14, 2018 Author Posted April 14, 2018 okay and what about if it doesnt use all 1000mbps how should i have it setup for it?
pollutionblues Posted April 14, 2018 Posted April 14, 2018 so i upgraded my internet to 1gigabit what would be the RIGHT SETUP for it in Miscellaneous? And also what Actual speeds do i have to put in the R1? The actual speed test or the speed that im suppose to be getting from my ISP which is the 1000mbps and 35 up? Enter the speeds you get from speedtest.net, then allow the Netduma to do auto setup. As BD said you won’t get the full amount you pay for due to hardware limitations of the Duma but auto setup should get you the highest speeds possible.
RL317 Posted April 14, 2018 Posted April 14, 2018 Since you can't get exactly 1Gbps anyway, I'd suggest turbo only and then testing different sliders to find out what suppresses congestion the best. Reactive is good for turbo only as it'll give you as much bandwidth as possible without losing the ability to use congestion control as you would with super turbo. And cookies to keep geofilter tick boxes saved of course
Administrators Netduma Admin Posted April 15, 2018 Administrators Posted April 15, 2018 Great advice from everyone - let us know if you need any further help!
