abc123 Posted December 29, 2014 Posted December 29, 2014 Is the included power supply, which is unusual for the RB951G normally it is 24V 0.8A. Where as the provided is 12V1A, anyways I am trying to get rid of the following issue (too tall when plugged in): So i'm thinking about replacing it with: http://www.amazon.com/Wall-Adapter-Power-Supply-12VDC/dp/B006GEPUYA As this is a 12V1A power supply, please let me know if this would work as according to the supplied power supply this should be a suitable replacement.
Guest Netduma Fraser Posted December 29, 2014 Posted December 29, 2014 In the future people will have a normal power supply. We just wanted to get people the units as quick as possible. We cant give advice on other power supplies im afraid.
abc123 Posted December 29, 2014 Author Posted December 29, 2014 "The voltage range for this device is 8-30V, so you can choose any adapter in this voltage range, anything above 0.8A should work fine."
abc123 Posted December 30, 2014 Author Posted December 30, 2014 The below stated is for educational purposes only: If you live in the US the following power supply is a suitable replacement for your netduma router: http://www.amazon.co...s=12v1a adapter It has the same specs as supplied power supply: Input 120V-240V Output 12V 1A The adapter plug (goes into the router) is 5.5mm x 2.1mm x 10mm (same as supplied) Understand that the above is given only as educational information, in no way is netduma or am I responsible for any damage the above power supply could cause to your router. You the owner are solely responsible for any damage that occurs from changing the supplied power supply with a new power supply.
wrathoftank Posted December 30, 2014 Posted December 30, 2014 The below stated is for educational purposes only: If you live in the US the following power supply is a suitable replacement for your netduma router: http://www.amazon.co...s=12v1a adapter It has the same specs as supplied power supply: Input 120V-240V Output 12V 1A The adapter plug (goes into the router) is 5.5mm x 2.1mm x 10mm (same as supplied) Understand that the above is given only as educational information, in no way is netduma or am I responsible for any damage the above power supply could cause to your router. You the owner are solely responsible for any damage that occurs from changing the supplied power supply with a new power supply. Have you already tried it?
abc123 Posted December 30, 2014 Author Posted December 30, 2014 Have you already tried it? Purely for science mine is in the mail, and won't be here until Wednesday.
Dillinger Posted December 30, 2014 Posted December 30, 2014 Purely for science mine is in the mail, and won't be here until Wednesday. I'll be following this as well. I am no electrician nor have I ever played one on tv, but from my limited knowledge of working near the industry it appears that replacement should be just fine. I just don't want to be the first one to test it as I hold my [Duma] in too high of regard right now.
abc123 Posted December 31, 2014 Author Posted December 31, 2014 Purely for science mine is in the mail, and won't be here until Wednesday. or Friday, January 2, 2015 by 8pm
Elikenui Posted December 31, 2014 Posted December 31, 2014 I'll be following this as well. I am no electrician nor have I ever played one on tv, but from my limited knowledge of working near the industry it appears that replacement should be just fine. I just don't want to be the first one to test it as I hold my [Duma] in too high of regard right now. My Precious...
abc123 Posted January 2, 2015 Author Posted January 2, 2015 purely for educational purposes this adapter worked perfectly. Router is running fine at normal temp for ~5 hours at load. Very educational.
Elikenui Posted January 3, 2015 Posted January 3, 2015 purely for educational purposes this adapter worked perfectly. Router is running fine at normal temp for ~5 hours at load. Very educational. Thanks for testing that out. I think I'll pick one up soon, the height of the plug with the adapter is awkward, I'm afraid it will get knocked loose in an inopportune moment of frantic button mashing.
abc123 Posted January 3, 2015 Author Posted January 3, 2015 Definitely, the original was very awkward. Just remember that when handling electronics, different power supplies may cause damage to your device. Although, my scientific expedition was successful...and documented here. I offer no guarantee, or support for this...nor i'm sure does netduma. That being said, mines working great still. perfect fit (including router side insert plug). Be aware that the cable on this was only like 3ft, which is perfect for me, but your mileage may vary.
decimalator Posted January 8, 2015 Posted January 8, 2015 I was actually happy to see the big power adapter to the power adapter, it made it high enough that I could plug it in on the same surger protector I had in my office with just one little open space above a big plug and I didn't have to shuffle stuff around. So, yay for awkwardly shaped power adapters.
Jman Posted January 8, 2015 Posted January 8, 2015 I was actually happy to see the big power adapter to the power adapter, it made it high enough that I could plug it in on the same surger protector I had in my office with just one little open space above a big plug and I didn't have to shuffle stuff around. So, yay for awkwardly shaped power adapters. I also had one open spot on my surge protector!
II Z IE IR O II Posted January 26, 2015 Posted January 26, 2015 Just an FYI.....There's a new type of adaptor that is shipping with the R1. I didn't compare height next to the original adaptor but all I know that its different. It looks to be shorter though
abc123 Posted January 26, 2015 Author Posted January 26, 2015 Just an FYI.....There's a new type of adaptor that is shipping with the R1. I didn't compare height next to the original adaptor but all I know that its different. It looks to be shorter though yeah they mentioned starting to ship a normal US power supply eventually but i was an early adopter to the extreme so I didn't get that.
fuzzy clam Posted January 30, 2015 Posted January 30, 2015 @ The duma crew are you guys shipping a new power supply with the dumas to the US yet.And if so how would i go about purchasing one ?
Guest Netduma_Iain Posted January 30, 2015 Posted January 30, 2015 I'll get Luke to answer this one, its more a logistics issue atm I believe.
Guest Netduma Luke Posted January 30, 2015 Posted January 30, 2015 @ The duma crew are you guys shipping a new power supply with the dumas to the US yet.And if so how would i go about purchasing one ? We're looking into bulk ordering and we have a sample on its way to us to test. If it works, we will order a large batch in but I think this whole process will take a while though (talking months not weeks). I would love to say I recommend you buy this adapter from X or from Y but as I won't have tested them, I can't give that advice.
fuzzy clam Posted January 30, 2015 Posted January 30, 2015 @ Luke i completely understand,so many legal loopholes and things like that.And i know testing something new takes time,thanks for the reply.
abc123 Posted January 30, 2015 Author Posted January 30, 2015 Hints why this is purely for educational purposes the test showed nothing invalid in the multimeter testing, also has been running with this power supply since it arrived Friday, January 2, 2015 by 8pm. Unplugging and plugging it back it also causes no power surges what-so-ever. But I cannot tell you that this power supply is 100% going to work for you, and netduma isn't going to either as they haven't tested it either. There is no guarantee that you won't get a faulty power supply and thereby be stuck with a fried netduma. So this is a use at your own risk.
fuzzy clam Posted January 30, 2015 Posted January 30, 2015 I'm gonna take a chance and roll with that other power cord.And as always i know your advice is for entertainment and educational purposes only.And abc LLC can in no way be held responsible for results different from his own and these results are not typical,so use at your own risk.There i feel i have covered you coming from a legal stand point Still gonna order the plug thou
lukasz Posted January 31, 2015 Posted January 31, 2015 Can someone post picture of uk power supply for R1 cauose i woes doing cable managment and i end up with 2 ps and dont know witch is form R1 and witch is from old tplink
Elikenui Posted January 31, 2015 Posted January 31, 2015 Can someone post picture of uk power supply for R1 cauose i woes doing cable managment and i end up with 2 ps and dont know witch is form R1 and witch is from old tplink Look at the very first post in this thread, abc has pic of the back of the R1's power supply.
