Media Reciver 400 does not work with Netduma why?
Media Reciver 400 не работает
с Netduma почему?Media Reciver 400
 connected via cable five seconds shows then shows a very short and then stops showing I can not watch TV
use port forwarding and open ports 1 - 65535 tcp and udp for that device and see if that solves your issue.......before doing that though please make sure you have given your media receiver a static ip address and that you have disabled UPnP.. Please let us know if that solves your issue!
Hi, welcome to the forum! Please let me know if Big Dog's solution above works for you :)
where to set a static ip address
You can set a static IP in Settings > DHCP Lease. Tick 'Reserved' next to your media receiver and then type in the last few numbers you see on its IP address in 'Host Number'. (For instance, if your device had the IP of 192.168.1.100, you would type in '100').
I hope this makes sense, please let us know if you have any questions :)
thanks for the help but it did not help
  Media Recever -Model MR400
SER.NR.; HDD50455LRC
problem still exists
Was this provided by your ISP by any chance? If so it may be locked to only work when connected to their hub where it can check you have an active subscription, switch it back and see if it works immediately
