Jettman Posted July 24, 2017 Posted July 24, 2017 Hey guys im having a problem on DSL Reports. i really love my COD games and hit detection means everything and im trying to get an A+. anyways the problem is, when i try test and get my results, the ping bar will be there for two seconds then it will disappear so i wont know what pings im getting and when the test ends it wont show me any results like- overall,quality,speed and buffabloat. all blank. if anyone has had this problem and knows how to fix it, please let me know, thanks
iAmMoDBoX Posted July 24, 2017 Posted July 24, 2017 Hey guys im having a problem on DSL Reports. i really love my COD games and hit detection means everything and im trying to get an A+. anyways the problem is, when i try test and get my results, the ping bar will be there for two seconds then it will disappear so i wont know what pings im getting and when the test ends it wont show me any results like- overall,quality,speed and buffabloat. all blank. if anyone has had this problem and knows how to fix it, please let me know, thanks Don't test on a console or a crap computer/browser lol
MrBrutalFrosty Posted July 24, 2017 Posted July 24, 2017 Hey guys im having a problem on DSL Reports. i really love my COD games and hit detection means everything and im trying to get an A+. anyways the problem is, when i try test and get my results, the ping bar will be there for two seconds then it will disappear so i wont know what pings im getting and when the test ends it wont show me any results like- overall,quality,speed and buffabloat. all blank. if anyone has had this problem and knows how to fix it, please let me know, thanks mines been doing it to man its on and off aye
Zennon Posted July 24, 2017 Posted July 24, 2017 Do not rely on a remote site test, use a local test like ping plotter after the 14 days trial it becomes the free version. I have no clue why people have got obsessed with a remote tester, for me only a local test will yield the correct results.
N3CR0 Posted July 24, 2017 Posted July 24, 2017 Do not rely on a remote site test, use a local test like ping plotter after the 14 days trial it becomes the free version. I have no clue why people have got obsessed with a remote tester, for me only a local test will yield the correct results. Exactly. I find DSLReports inconsistent. When I was on Virgin, according to DSLR I had less BB than what I have now on FTTC :/ Also, I always have A+ on BB and still had bad hit detection alot of the time.
fuzzy clam Posted July 24, 2017 Posted July 24, 2017 Hey guys im having a problem on DSL Reports. i really love my COD games and hit detection means everything and im trying to get an A+. anyways the problem is, when i try test and get my results, the ping bar will be there for two seconds then it will disappear so i wont know what pings im getting and when the test ends it wont show me any results like- overall,quality,speed and buffabloat. all blank. if anyone has had this problem and knows how to fix it, please let me know, thanks That has happened to a friend of mine before,I believe a firewall or virus protection was the issue but yours might not be the same issue. And as said above PP is a much better way to test and get the results your looking for,I also sometimes leave PP running while I game just to see what's going on with the stability as I have cable and we all know it sucks for gaming.I'm not suggesting you run PP while gaming but would definitely recommend using it to check your lines quality.
