Fifa lag and lag in general!!!!
Iilukas210
Hello there guys of netduma and community. I'm new to the forum but I have had the netduma for over a year now and I have got to say it was money well spent I do have a slight issue I'm hoping I can get help with. I play fifa 17 a lot but I always suffer with input lag and delay also jittery games with loads of spikes I have set up a bqm monitor on my line if you would like to see my current set up is vm hub 3 in modem then R1 then hardwired xbox console please help.
I have resized the ping graph so your IP address is not showing, here it is.
Hi zenon thanks for the reply unfortunately I don't have a super hub 2 I never have had one I was put straight on to the hub 3. I have asked for the hub 2 but they do not issue them out anymore I'm so fustrated I just want to game with out problems
I suggest  buying a H2 from ebay and learning to MAC clone or move to fibre.
I would do the latter.
Hi thank you for response how would I mac clone and wouldn't virain have to activate the new hub ? Also I thought all virgin was fibre
Sounds like you've got some good advice so far. I assume Zennon is talking about cloning the hub 3 MAC address to use as the hub 2's mac address so there is no issues with getting it working with Virgin. In which case you'd copy the MAC address of the hub 3 and then on hub 2 interface change the MAC to that.
Hi fraser thank you for the reply I will see about ordering a hub 2 and I will get back with the results thank you
Good luck with that, lots of virgin customers have tried (me included) and are told hub 2 AC cannot be registered on the network now and with todays news of the hub 2 having a flaw in security with default passwords i doubt they will ship one unless you really annoy them with multiple calls daily someone may give in lol.
This is my BQM
1553a50504da061a4683134de80d52d810014c26
If they will not let you have the 2 and the 3 has the Intel puma 6 cpu issue I would tell them you want to leave without paying out your exciting contract as they are surely breaking it.
Vote with your feet and move to fibre fella's.
Wow ziltoid at least I'm not the only with the **** hardware virgin are supplying you would have thought they would give customers compensation or some thing back but typical big company BS.... and zenon I was on the understanding all virgins lines are fibre optic or am I mistaken lol
Cable, although they do a new to the market fibre product.
