Help for destiny pvp
Hi everyone, I am a netduma user for 2 weeks, I know several problems with the servers of this game, in the strict mode we can not propose to make mistakes at every game start In geofilter mode by propagating every now and then causing errors like beaver or tapir and leaving the game, these errors in osiride mode cause run-off loss and give a lot of annoyance I noticed that even in geofilter mode I happen to play with whole teams 10,000 miles away causing lag Unfortunately, I thought the product was more reliable and I was so sorry They came back to using the product when it is fully reliable, now only cause problems and anger
Sorry the bad English but I used a translator ... ps there is no section dedicated to Italian users
Do you have special settings that you can not create anymore? I'm so sorry to hold the modem down and use my fritzbox
Try going into Settings > Misc and putting in these cloud numbers: 34,31,28
With Destiny, we are going to update our cloud this week to add several servers to the Geo-filter, which should prevent most of the problems you have mentioned.
The Geo-filter is designed to get you the best host - it cannot prevent distant players from connecting to the host. The people you see 10,000 miles away are likely other players. Please make sure you keep strict mode turned OFF for Destiny.
turn strict off as said above.
then using using the geo filter set the range to 1000km IF you see a padlock on the map expand your filter to cover that padlock if you do not see any padlocks reduce the range until you do.
once the padlocks are covered your games should be better and beaver / weasel etc errors will be reduced to almost zero , but  until the cloud update there will still be some lag (sorry).
in the netduma screen do the following :-
1.goto settings
2. miscellaneous
3. scroll down to cloud settings
4. input the numbers 34 , 31 , 28
5. press "apply cloud settings"
hope this helps it works for me
Ciao ragazzi l'impostazione nuvola avevano già fatto ... non mi resta che aspettare che l'aggiornamento ... ma c'è la possibilità di avere il nat 1?
i have ps4
i have ps4
NAT tipo 2 o NAT tipo 1 sono buone su PS4. Entrambi significa che non dovresti avere difficoltà a giocare.
____________
NAT type 2 or NAT type 1 are good on PS4. Both mean you should not have any trouble playing games.
ok thanks...
Do you know when server updates come out?
Fraser is working on the next cloud update now. Thank you all for providing ID's. We'll let you know when you can switch to the new update.
I can confirm that you can all use the cloud numbers 35, 32, 28 with strict mode off. This version has all of the ID's you guys provided me with added, so you should have a more stable connection.
Hello where do I find the id you're talking about?
The ID's I am talking about are blocked servers showing up on the Geo-filter map when people receive error messages on Destiny. I asked in other threads for ID's to the blocked servers, which are likely to blame. These have now been added properly to the Geo-filter, so if you use the cloud numbers above you should have less Destiny errors.
Please apply it again as you may need to do it twice for it to properly propagate. If you're getting errors after this please provide me with the IDs of what is being blocked.
  • 2 weeks later...
  • 2 weeks later...
These have been posted before but they are still locked using 35,32,28 (is that still the latest?)
14342af5d1b35358 oregon
4334723dd1e25358 oregon
7b6d25f00a1a989d ireland
Thanks for the ID's I'll add them as soon as I can
Okay are we sure we should be adding all the IDs to the cloud? I mean a lot of other things could be going on to give users errors and i feel all these ID adds are making more connection problems... 30, 28 28 worked great for a long time and then random people had you add more IDs to the cloud and nothing but connection issues since. Are you verifying these IDs are truly an issue.
We do check out every server we add to the cloud; we started gathering ID's because of an update that occurred which led to a massive increase in errors, so we had to find out which servers were causing the issue. It's still ongoing though as you can see - you might find that you have a better experience just using Auto Cloud and Bleeding Edge whilst we're building a new cloud version.
02348f5ad1a15358 oregon
This is has been the worst I've seen in quite some time for me. I am getting beaver errors galore, getting them in games I am already several minutes into. It feels like servers are changing during the game.
D2 beta next week is going to be interesting for sure.
Cheers for these Willphule. I believe this is all down to Destiny 2 taking over some of the Destiny 1 servers and a change-up happening there. Once Destiny 2 is in full swing then hopefully this will all settle and become more stable again, but for now we'll just keep updating the cloud when we get the chance.
If anyone else spots any servers when you're kicked from the game, let us know the ID please :)
Hey, just to let you know I put out a cloud update last night for Destiny/Destiny 2. You can now use auto&bleeding edge cloud and shouldn't get booted.
with cloud open
ID: ed36a772d38c4348    Distance: 1973km
Was that on the latest cloud with strict off?
